Question about Apple iPod nano
Sound from only one earpiece
My iPod only plays music from one earpiece. I have tried several different headsets that are known to be good. Is there a balance adjust feature?
can you help me, regarding my ipod 4gb first release, it suddenly not charging.
thank you very much!
jen
Posted on Apr 16, 2008
    Problem Solver:
  • 10 Answers
Go to setings and EQ and turn to off, it is already like that probly one of the ear phone jackets broke, try replaceing it for less then half of the price :D
How can I fix the sound in my LG HBS 780 bluetooth headset with out taking it apart?
I doubt you can, the problem may well be the earpiece speaker has a fault or an issue with its bluetooth decoder part it may be worth contacting LG to see if they can help you in some way by exchange?
LG Support UK Customer Service and Technical Support LG UK
Hope this helps..............
Jan 08, 2018 | LG Cell Phones
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
My headset just stopped playin sound???
If the stereo earphone output socket is in tact (not broken), most likely the problem maybe the Earphone-cord is broken.
May 13, 2014 | LG HBS-700 Bluetooth Headset
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
My zeppelin has stopped playing altogether, ipod works fine, but no sound ... yes i have turned it up!
if the aux input at the rear works, then the fault relates to the docking arm or the interface on the back. (Does the ipod charge on the docking arm, have you tried another type of ipod, as different ipods have different connections through the arm!)
if the aux input does not work, then the main board/amp/pse could be an issue.
if the model is more than six months old it will probable have the known problem boards, so contact b and w servie and they should check it out.
Mar 02, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
I have an H-12 headset and I wanted to know can I listen to my music on my phone as well using this earpiece
ive owned 4 different heatsets(bt) and only one that i could get to operate on my phone for both music and talking together via a pause button they made to allow both to be functioned in at once ok aswell that headset has 2 earphones attached also try going into the music setting and try another output for the music sometimes it will help you achieve your results have patience and i hope this helps ok
Nov 17, 2010 | Motorola Mobility Motopure H12 Bluetooth...
My computer works great but I have no sound
try to play any music theres a sample music under the music folder
if you are getting an error message that theres no sound device available then you have to reinstall the drivers for your sound card
if you are not getting any error message, check if its not in mute
if its unmute try to use a headset and try to play music
if you are using a speaker check if the cable is properly connected (normally its plugged in to green port at the back) and its turned on , make sure that the volume is set to middle.
if still not working while its plugged in the back try to plug a known good speaker in the front port
Sep 06, 2010 | E-Machines eMachines Desktop PC
Hello I have my problem is that my jailbroken ipodtouch(2nd genertation) will not play music.It wont play sound the songs play but the sound you cant hear.Can any one help me?
Did the songs you're trying to play work previously/is it all music on the ipod? I believe if you plug the ipod into your computer and hit the restore button in iTunes it wipes everything and resets the factory settings. Seeing as jailbreaking it technically voids the warranty, there's no "official" way of fixing it - but this has worked for me in the past. It could also be a problem with your headphones or the headphone jack. Before wiping it, I'd test it with some different headphones to see if that solves your problem. You can also try a reset on the iPod itself by pressing the sleep and home buttons at the same time for about 10 seconds. This doesn't erase anything, but it does reset the device. Since there are so many things it could be, you may want to try the less severe ones first, then back up your music and the like before doing the iTunes factory reset - then bring it in to Apple to let them know that you can't play music.
Jun 10, 2009 | Apple iPod touch
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
Feb 22, 2009 | Motorola Mobility S9 Headphones
Apple iPod nano Logo
113 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
