Transfer info is there some software that i can buy to transfer all my info from my old computer to my new one ?
    Sergeant:
  • 221 Answers
Windows has a 'Files and Settings Transfer Wizzard' where you can transfer files from your old computer to your new one.
Click on Start . . .
All Programs . . .
Accessories . . .
System Tools . . .
Posted on Apr 16, 2008
Tip
Migrating XP to Windows 7 (Using your Network)
If you are thinking of buying a new PC and trying to replace an old XP system to a new Windows 7, you might want to transfer your old favorite files to your new computer. Either transferring through a Easy Transfer cable, Network, or via USB
This procedures assumes that your old XP is still working and connected to your home or office network. and your new Win 7 is also connected as well to your networkBoth of your system and computer must be connected to the same network, either in the office or home, because it is easier to transfer files in this way, effectively and efficiently, this is practical than using USB flash drive or any external disk, though the process is similar.
Ensure that you have the Win7 InstallationDVD, or the Easy Transfer Software fromMicrosoft website, ready to be installed on your XP system. but be aware this is for 64 bit version system only, please visit Microsoft website search and download Windows easy Transfer and select "x86" in the file name for 32 bit or 64 bit, install this the same way you've done with ordinary software. In your Win 7 however, this software is automatically installed so do not bother yourself.
In this instance you will be asked if whether you want to transfer your whole data from all user accounts or to just specific user only, in this process you can also select specific files to transfer, but in order to transfer all accounts, both of your XP and WIN 7 must be logged as an Administrator.
So this procedure is Migrating through NETWORK, the other two procedure is Easy Cable Transfer and USB, external Hard disk.
1- Prepare both systems and ensure both are connected to the network and working, Start the XP computer and log in as an Admin
2- IN XP , Open up the and start the Windows Easy Transfer DVD, and look or browse for SupportMigwiz. if you have downloaded this simply select Start> All Program> Windows Easy Transfer for Win 7, it will load automatically. Simply read the screen for additional info and click Next
3- A new screen pops out and please select a Network as an option to transfer
4- Click This is my OLD COMPUTER, Still in XP Windows Easy Transfer will then generate a password for the transferring process, because in order to transfer files through the network you will be required to enter a password (record the KEY)
After you enter the key, at this time Windows Easy Transfer makes the connection and scans the Windows XP system's contents and components. Once this is over, you can practically choose which data you want to transfer, or you want to import, just like customizing the items you wish to transfer. After you have decided which is which, click Transfer, then a progress bar will appears the process occurs.
The final screen will then show up indicating the process is complete. Confirm to see if the file you have chosen was actually transferred, then close all window, including the Easy Transfer Windows.
Restart your computer, please. Congratulations!
on Jan 08, 2010 | Computers & Internet
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Transferring upgraded software to new computer
unfortunately, it doesn't work like that. you have to install it on the new computer. Just dont forget to deactivate it if you plan on removing it from the old computer. if you have an upgrade then you just need to install cs4 upgrade and then it should ask you for the cs2 serial number.
Aug 04, 2009 | Adobe Creative Suite 4 Design Standard...
I have a computer where the MOBO and CPU went bad and I replaced. The old computer came with Windows Vista installed on it, no CD. Now, Windows Vista won't boot and windows start up repair is activated...
The problem is when Vista was installed on the old pc it only recognizes that pc so you will need to buy a copy of Vista and install it on the new pc. And if you don't want to loose your info you can buy a ide/sata to usb cable and hook it up to your new pc to transfer your old info across. Hope this helps.
Jul 19, 2009 | Computers & Internet
I would like to know how to transfer data and software from a old computer to a new one I am considering to buy.
There are a couple of simple and fast ways to do this. They both depend on the systems. If you have two systems that both have network interfaces on them, the simplest way to trasnfer the data would be to connect the two computers together using a router (Linksys WRT54G about 60.00 at Staples). You can then share the drive on your old machine, and copy your data to the new machine using your network.
The second, which is slower but cheaper, is to buy a USB flash drive. 4 GB should cost about $25.00. When this device is inserted into a USB slot, it acts as a second hard drive. You can copy data from the old machine, to this and then move it to the new machine.
Good Luck
May 23, 2009 | HP Computers & Internet
Transfer data from old computer to new computer
Yes... You can use the synchronize tool from the explorer.. Tools--- synchronize..
Let me know if you have any difficulty in using that...
Mar 22, 2009 | Microsoft Windows XP Professional SP2
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
My transfer disc is not copying on to my new computer.
if one way to solve this. just u do that you remove the harddisk from your old computer.
and connect in your new model(just remove ur cd drive cable then only you can connect the harddisk).
if u want to copy old files from your cd to computer. use isobuster1.1ver. but if all your old software
are not possible to on a vista
Jan 29, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
