Question about SanDisk Sansa e260 MP3 Player
Sandisk e260 is frozen
Ok my sandisk e260 is frozen on a song page thing and it been like that for about 20 mins now i dont know what to do
  • Krazy Kwesi Apr 17, 2008
    I pushed the record button and then when i tried to go back it froze and the blue light on the system disappeared right when i connected the charger to my sandisk. Ive pushed the menu button many times and did a in and out charger to my mp3 still now working thought.
  • Anonymous Apr 18, 2008
    the menue button is stuck and the blue light is on and i can't turn my mp3 player off
  • 3 Answers
I had same problem with mine...try pressing the menu button and the select button (the big button in the middle) at the same>it should work.
Posted on Apr 15, 2008
Sansa mp3 e260
Just close it if you dont want WMP. IF what you mean is i dont know how to download songs then go to The SYNC tab on WMP but first make sure you are using WMP11 or Higher. After clicking the SYnc tab then Drag the song files to the empty spot below the playyers picture and clik The Load Songs button or Synchronize button. Hope this helpsl
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e60
Try using WMP or explorer to transfer songs
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
Frozen in song.
The sansa e260 seems to have a hell of alot of faults. If SanDisk brings out a firmware upgrade definately take it, also I would strongly suggest that you write a letter to ScanDisk letting them know the grief it has caused you. I have an e260 and it has not had any problems so far, so I guess theres a little give or take sorta thing happening here.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
you may be able to pull the battery which will reset it. It does require disassembly of the device to do and you should be able to google search it to find disassembly help. Check the users guide for help too it cant hurt
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
Dec 17, 2007 | SanDisk Sansa e260 MP3 Player
How do u put songs in the sandisk sansa e260?
You must use windows media player10 or newer. Add music to your library, plug in your sansa then go to sync tab in media player, there will be a button saying sync list. select all music.
And away you go..........
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
Songs Not Loading On Player
Did you use Windows Media Player to format?
WMP never does a thorough format.
If so, try formatting thru My Computer. Right Click on the Device (e260) and select FORMAT.
Then try transferring your music again.
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e260 MP3 Player
I DONT KNOW HOW TO REFRESH MY SANSA MP3
hold down the on button on the bottom left hand side, keep holding it till the sansa turns itself off.  After its turned off switch it back on, ive had the same message up many times
Oct 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
Try holding the power button for 20 seconds to hard reset the device. Then try turning it back on. If that doesnt solve it, youll need to do the following. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 24, 2007 | SanDisk Sansa e260 MP3 Player
Frozen
You can put it into recovery mode and you should be able to fix it. First download this from the SanDisk Website; http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Next, put your device into recovery mode. - turn the device off (hold button for 20 seconds) - slide the 'hold' switch into the hold position - press and hold record button while connecting it to the PC. Keep holding button until you see new hardware found on the PC. Then run the recovery tool from sandisk. Make usre you select "format" when prompted, this will erase all of the information on the device, as well as, install an older version of the firmware. Best of Luck.
Sep 08, 2007 | SanDisk Sansa e260 MP3 Player
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it doesn't then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
