Question about Sony Ericsson W600i Cellular Phone
Cellphone splited in two
The cellphone accidentally splited in two, and the cables were disconnected, tried to re connect them but nothing happened, is there a way to fix this
Same thing happened to mine.
This is what I did:
There are 2 connectors and 2 cables.
Remove the battery.
Set the phone down with the battery facing up and the screen facing down with the antenna pointing away from you.
There are 2 connectors at ~45 degree angles. \ /
One of my cables had a blue spot of paint on it.
It goes in the left connector with the paint visible.
The other cable goes in the right connector.
Replace the battery and everything should be good to go.
If not, check the connections.
You may have to flip the unmarked cable. (I don't know if there is only one way to insert the cable.)
Once I got them both in correctly and tested the phone, I used a sharpie to paint a line on the right connector and cable for future identification.
(Then I promptly backed up my phone).
Willowbend
Posted on Nov 01, 2008
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them replace the flexcable for you.
Posted on Apr 20, 2008
Am trying to upload pics to my computer. Has worked in past but now nothing happens? Help?
Need more information. Cellphone? Camera? Model?
From the little info that you've given, it would appear that one of two things has happened:
1. You are doing it differently than you did in the past.
2. Something is damaged - connector on camera or computer or the cable between the two.
For example, it isn't immediately apparent on a Galaxy Note 5 how to transfer photos. If you use a cable not capable of supporting photo transfer, you can't do it. If you do use the correct cable, you then have to go to the menu to tell it that you intend to use the USB connection for photo transfer.
Jan 06, 2017 | Cameras
Razr v3 and LG HBM 770
how actually you are connecting the device elaborate it please
Jun 24, 2008 | Cell Phones
When i connect my usb data cable on my nokia7230 It says that"connected device uses too much power.disconnect cable"any one please help me. thankz in advance
there might be a problem on your USB cable, a little rust could make some problems to your connections, try replacing it or have your technician check your cellphone
Jun 24, 2011 | Nokia 7230 Cell Phone
I accidentally inverted the ground and 12v connection coming from the radio. i realized this a few minutes after trying to figure out why amp wasnt powering up. will it still work once i re-establish...
This should still work if not then check fuses first. If no big spark happened when you turned it all on then you are definitely good to go. The only way to know for sure is try it out
Mar 24, 2010 | Car Audio & Video
Accidentally disconnected TI Connectivity cable during transfer
you are going to have to completly start over reinstall your drivers
Mar 09, 2010 | Texas Instruments TI-84 Plus Calculator
I am updating my N73 mobile software, but after updating .cellphone is not on.
I am sure your handset does not completed is updating during installation from net. Reason network or data cable connection disconnected from computer. Same problem was happened with my Nokia N73. If i am not wrong then when you press your power button, nothing is happened. Its look like a dead body. Don't worry just visit Nokia service center and tell them you want to install the update version & hand over the phone. You can't install the software from home, because your hand set complete dead. Its takes 2-3 hours for installing. But as per there work load may be its take 2 - 3 days for service center people.
Thanks & waiting for your feedback.
Feb 03, 2010 | Nokia N73 Music Edition Smartphone
Inside screen is blank; keyboard and phone, outside screen all working fine. inside screen used to be able to be reset by closing and reopening but now nothing makes a difference. Have powered Off/On...
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Nov 08, 2009 | Cell Phones
When my balance computer is turned on the balance digital technology logo loads on the screen and then just disappers to the bottom of the screen. the screen is now black and xp is not in sight. Nothing...
no there is nothing wrong with the motherboard, please shut it down, disconnect all the connectors, leave it for 10 or 15 min then connect only keyboard mouse and power and monitor cable, and switch it on, see what u get. let me know ok? i am waiting for ur reply :-)
Aug 24, 2009 | Balance CN6555 Notebook
Motorola v3x problem
The connection from your LCD to the systemboard might have a loose connection or might be disconnected.
If you have the skills, you can open up the phone (back part or keypad part) there should be a screw at the back and u must use a creditcard or any card similar to slide out the casing.
On the uppermost part of the board should be the flex which looks like a brown film and it has connectors that hooks up with the board. Just try to re seat it.
Hope this helps...
Jul 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Sony Ericsson W600i Cellular Phone Logo
278 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
