Question about Garmin GPSMAP 60CS GPS Receiver
Garmin 60csx turning off while in use
I have had my Garmin 60csx for about 8 months & love it. Recently I took it with me down to Mexico. The unit keep turning itself off. I thought maybe I bought bad/old batteries, but I bought new ones & it still happend the next day. Any help would be greatly appreciated.
  • 3 more comments
  • chmi Jun 02, 2008
    Mine 60CSx does the same thing. I turn it on and it works for 20sec and then the screen just fades out. I tried new bateries and the problem is still here. When I plug it in the computer the same thing happens.
  • DustOrBust Jun 03, 2008
    Used my Garmin 60csx for a Mountain Bike Race in Portugal and it started powering off with no apparent reason. Changing batteries did not help. Also made sure that the batteries were seated properly. Garmin were sponsors of the event and exchanged the unit for a new one. A number of competitors experienced the same problem as mine.
    The new unit worked fine initially, but has also started powering off during use.
    Sources say that Garmin has no idea what is the cause.
    I'm really disappointed !!
  • duc_boy Jun 14, 2008
    Mine is doing the exact same thing, except it only worked for an hour before it started doing this. It does work when powered via USB, just not off batteries (and I've tried multiple sets). Sounds like a manufacturing defect.
  • Anonymous Feb 03, 2009
    I has something to do with software, trust me
  • Anonymous May 01, 2009
    GPSMAP 60 CSx work fines until I try to do a "go to" for a waypoint, then the screen fades away and the unit powers off.
I've had the same problem until I updated the software to version 4.00.
To see your Software version push Menu 2x, choose Setup, choose System, push Menu, choose Software Version. It will tell you the software version on top.
You can download the latest version on the Garmin website.
Enjoy
Posted on Feb 10, 2010
It may be the batteries moving after a bump especially when cycling. I lined the battery cover with thin single sided canopy tape and bought the largest NiMh 2650 mAh batteries. Now the batteries don't move after a shock. Garmin should know the problem, they built the 60Csx with poor metal tab battery compartments, should have been spring loaded.
I also had problems with wild battery fluctuations and the appearance of excessive battery consumption. Again it was metal tabs instead of wires between the battery board and the main board. I soldered two thin stranded wires between the main board and the battery board.
I haven't had any problems for 1.5 years since i did both fixes. Love the Garmin now! >RocketRob
Posted on Sep 11, 2008
OK, I've managed to overcome the problem :D I've formated the micro SD card and now it works without any glitches :D
Posted on Jul 22, 2008
My Garmin 60csx won't locate satelites
take a look on the old messages and You will find a solution posted for me.
Sep 30, 2014 | Garmin GPSMAP 60CSx GPS Receiver
My unit garmin 60csx have not alarm clock. Is it normal? it has a cronograph!
It is normal - the 60Csx GPS does not have an alarm clock. There are alarms for proximity, depth, off course and anchor drag, only.
You can download a copy of the manual here.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 10, 2011 | Garmin GPSMAP 60CSx GPS Receiver
My device has seemed to have lost its ability to acquire satellites. Any suggestions? It's Garmin GPSmap 60CSx. Thanks.
I would try a reset and firmware update first. To Reset the unit hold the Page and Enter keys down while you power up the unit. hold them down until you get a prompt asking you if you really want to reset.
Garmin has a free software called webupdater. this will put the latest software in your unit. If there is a GPS chipset software available please apply that also. It will be in the list when you run webupdater.
You may want to try an external antenna also to see if an internal connection came loose.
Jul 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
The coordinates that I get are 30 metres off from the other GPS units that we geocache with. My settings must be off.
Yes, have you enabled WAAS on your 60CSx? WAAS is an acronym for Wide Area Augmentation System, according to the instruction manual an FAA funded service to improve overall integrity of the GPS signal through North America.
If you are in an area which is not serviced by ground stations, having WAAS enabled may degrade the signal from the GPS satellites. Try enabling or disabling this feature.
To do so, acess the System Startup Page. On the Setup Menu page, highlight the System icon and press Enter. WAAS is the second available setting on this page.
Make sure your batteries are fresh; I prefer alkalines in this model. Set the battery type in the System Setup Page, same page as noted for WAAS above.
Another thought is to be sure you have the latest Garmin software installed. Visit their site to download the latest and greatest, free, of course.
May 20, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Buzzing noise when i turn off Garmin 60CSx
This problem is Mac OSX related and can be solved using Cleaneject http://www.javawa.nl/cleaneject_en.html
The OSX operating system creates several invisible files and folders on USB-disks, camera's and GPS devices and the Garmin GPS devices can't cope with these invisible files and folders.
Cleaneject erases the invisible files and folders.
Feb 27, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I have a Garmin 60csx that won't power up
On my GPSmap 60CSx the screen fades away after powering on - just like the battery is empty. Changed battery and used USB power. Always the same. When removing  the 2GB micro SD memory card then it comes up. Replaced the memory card and now it powers up fine. Seems that the memory card is damaged or causes a short circuit.
Apr 26, 2008 | Garmin GPSMAP 60CS GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CS GPS Receiver Logo
688 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
