Adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Testimonial: "No, not at all I had a new belt put on and the technician measured both sides and adjusted to same height."
ok,, look under the mower bed at the cutter hights,,they should be both the same hight,,if one of the cutter heads are out of alinement then you could have hit some thing when cutting,,or it could be the new belt pulling the mower over to one side maybe the bearings in the mower have worn out thereby throwing the cutter head out,,or one of the cutter head blade's are bent down even blunt blade's can make the cut out of true,,,to be honest without seeing it its realy hard to know whats wrong with it,,but at least you have a fuw things to look for,,hope this is of help
Sounds like the shafts for the blades have shifted in the spindles. A bent blade only causes vibration but not stepped cuts, remember it is rotating. In addition deck heaight is not an issue side to side then the cut would be sawtooth in appearance.. If stepped cut then it is a problem with the spindles and bearings slipping in the deck.
If the bar/rod adjustments are set even--- than check the guide wheels on deck make sure their adjusted correctly
