Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
What kind of capacitors should i use to replace the 180uf 30v ones
I opend the monitor and on the inverter board i found the two cap.s with raised tops i just need to know what to replace them with because i dont have any with the same
  • 176 Answers
Electrolytic capacitor usually blown up the top only in you can still reading the value in the body of the capacitor like the voltage and micro farad example 400V/33UF that's the value of the capacitor
Posted on Apr 16, 2008
  • jemuel osorio
    jemuel osorio Apr 18, 2008
    Thanks for the reating
Viewsonic VX924 monitor SMPS failed. Replaced all bad capacitors and have found that one pair of inverter driver transistors has failed. They are marked as DKQR (They are apparently Rohm 2SC4672...
When the DC filter caps no longer filter out high frequency AC, that AC will be fed through out the circuits and cause damages such as the inverter frequency will be running at the wrong frequency and caused overheating.
The service manual does not show the sch of the power supply/inverter board because it is not designed by Viewsonic.
Mar 27, 2011 | ViewSonic VX924 19" LCD Monitor
My 213T monitor began to darken on the lower third of the screen about one week ago. Two days later the screen went completely black. I pulled the back off and found three capacitors positions C-012, C-013...
Your unit has bad caps in the inverter and the power supply. The bad caps in the inverter causes a mosfet to short out and this blows the inline fuses on the inverter. After the fuses blow, the power light will still go on but there will be no power going to the inverter. It is possible to repair this damage, I have fixed over 40 of this model monitor. You can find more info by searching this model on badcaps . net. I can be contacted there as user 'bluto'
Aug 04, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There were...
Most cap meter does not have the ESR measurement function, the cap can look OK but it can have high ESR. Did you replace the bad one with LOW ESR, 105c type such as PANASONIC FM or FC series from DIGIKEY?
When the filter caps went out it may have taken out the components in the inverter circuits with it also. Check the transistors/Ic, inverter transformers.
May 10, 2010 | Xerox XG-91D 19" LCD Monitor
I have a viewsonic VX2835wm and when i turn it on the screen turns on for a second and then goes black. How do i re-set the monitor?
In this model the capactors hardly ever dome or vent. Usually you will see the top of the labeling on the capacitor has shrunk a little from it's normal size. If the monitor still has any kind of power (which it does from your comment) you or someone you know can replace those capacitors on the output side of the supply. If you're lucky this will solve your problem. If not, you can always try replacing the four brown electrolytic capacitors on the inverter board (the long board on the left when viewing the monitor from the back). There is a chance this could be caused by the inverter board or even a bad backlight, however I would bet it's the power board. If you don't want to replace the capacitors or replacing them didn't solve the problem, contact Viewsonic at and get the price of a new power board. They are pretty easy to replace.
Mar 15, 2010 | ViewSonic VX2835wm Monitor
I have a Samsung Syncmaster 932b LCD monitor. When I turn it on, the screen just flashes on and off, as does the blue light around the power button. I read up online and found that the capacitors on the...
savato321, Most black screen lcd monitor owners don't have the smarts to open up their monitors to do a VISUAL inspection of the "switch-mode-power-supply/inverter supply!!!! You're good. Now you will need to know some stuff about electrolytic filter capacitors! First, the "uf" or "UF" means micro-farad! It is just a rating given to express the storage capacity of the device. Next is the voltage rating. A 16v rating means that the capacitor should never be placed in a circuit where the voltage will exceed 10 to 12 volts DC. Your 820 uf cap rated at 25volts will most likely be in a 12 to 18volt dc circuit. Now for temperature rating. All caps have a maximum temp rating. Most clock radios, stereos, will use 85 degree centegrade rated caps. Printers,PCs,monitors, will use 105 degree C rated capacitors. Never replace with lower specification units! You can GO up but never DOWN. If 1000uf 25v is all you can get it's OK. If you can get 820uf 35v units and they are not too big and they will fit on the board sure you can use them. I would stick with the OEM design voltage rating. Electrolytic CAPS are polarized!! You must replace them + to + and - to -!!! If you screw -up they will blow-up!! The wire lead closest to the printed STRIPE on the cap will be the negative and the unmarked terminal will be the positive. If you visit you will get more info on recapping your SMPS. You can also watch some DIY videos at YOUTUBE for "lcd monitor repair" that might be helpful. Also visually inspect the SMPS/inverter printed circuit board for "COLD" FROSTY looking solder joints. They should all have near mirror finish to them. Let us know the name of the BAD CAPS you remove from your unit. You may even want to document with pics with a digital camera what you find. Well, good luck guy. 12fixlouie
Dec 24, 2009 | Samsung SyncMaster 932B LCD Monitor
ViewSonic Vx924 No power
If youcan take a picture or two of the boards in your system as close and clear as you can and go to our web page and email them to me I will check and see if we can help you find the problem.
Corporate Computer
Aug 14, 2009 | ViewSonic VX924 19" LCD Monitor
Proview PL926Wbi
On modern capacitors 2005 or up the capacitors can go bad and not even bulge at the top. I replaced a few in my moms flap panel monitor and found out that there were more that were bad and they didn't show any signs of damage but put your finger on one of those suckers and it burns like a smoking gun.
Apr 10, 2009 | Proview PL926WBi 19" LCD Monitor
Optiquest Q7B-3 Model Vs11147
Actually that model has an integrated inverter with the power supply. Should be part # xlm1700390004 they cost around 25 bux and are fairly easy to replace.
If you are handy with soldering you could check the three 470 uf caps on the board they are tank caps and when they go they do what you are describing. Open the monitor and look at the three black capacitors if the top is bulged they are bad. If you have a capacitance meter check the capacitance it will most likly be well below 470 uf the caps are cheap like 39 cents if you do go this route use 30v not 25v caps to be on the safe side.
Word of warning switching power supplies can kill you quickly never work on it live and let it discharge at least an hour before working on it.
Dec 11, 2008 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Monitor turns off after two seconds
Your inverter board is bad. They run anywhere from $30 - $80. They are very easy to replace. I have had this problem with three monitors and replacing the inverter board fixed the problem. Hard to say where you will find the part. Just do a search for 'inverter board' with your model # on any search engine.
Good Luck!
Oct 23, 2007 | CTX S762A 17" LCD Monitor
Proview PL716s computer monitor
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
537 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
