Does anyone know what the F-77-2 Code indicates on a Konica 7030 copier and is there a way to clear it so that we can use the copier? Thank YOU
77-2 is a finisher prob..Make sure nothing is under the finisher like a small trash can preventing the finisher from moving up/down.Turn off then on,if prob. still there remove finisher by pressing a pen/pencil in small hole inside finisher door and pull fin. towards you. This will let you use copier until service rep. gets there.
Posted on Jun 20, 2008
What does code F52 mean
It seems that your drum is asking for a new one.
Jul 24, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica minolta 7030 drum replacment
Is this a photocopier? If so then you will need a technician to fit this for you
Jan 02, 2009 | Office Equipment & Supplies
Konica 7030 copier/printer - service codes
Are you sure it's not 34-2.I don't see or know of a 32-4 in my service manual.If it's a 34-2 write back and I'll reset it for you.
Jul 24, 2008 | Office Equipment & Supplies
Konica 7030 tray # 4 code
You should contact Konica/Minolta for that information. That requires an tech engineer from K/M to fix that issue if it is possible to do or support.
Jun 11, 2008 | Konica Minolta Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 1112 service manual
I have a konica 1112 copier all of a sudden it gives me a black page no codes to read someone told me it is the cleaning blade is this hard to replace
May 14, 2008 | Office Equipment & Supplies
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
174 people viewed this question
jasbo
jasbo
