Question about Canon PowerShot A620 Digital Camera
Lens out, will not turn on.
Hey. I have a Canon Powershot A620. I put in full changed batteries in my camera. The lens is out and will not go back in. The camera will not turn on. It happen yesterday. I turned it on and turned it to video. then it turned off and the lens stayed out. HELP ME!!!!
Hazelovescoffee@yahoo.com
-Hayley
  • thonas May 05, 2008
    Same exact problem, but I also got a E18 error code on screen before it crapped out entirely
  • gojo1 May 24, 2008
    Lense came out did not go back in and now I have an error lense message to restart and this does nothing. camera won't work. I have had this camera since christmas and work fine until today Cannon PowerShot 560.
    Any help wou be appreciated
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 04, 2008
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Canon Powershot A 620
Check your owner / user manual. I had similar problem and it was caused by "Mode" and "Flash" settings.
Jul 23, 2009 | Canon PowerShot A620 Digital Camera
Lens cover will not close
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
ARCLIGHT1217
Sep 15, 2008 | Canon PowerShot A620 Digital Camera
Cannon A620 won't work
I cannot access my 'Date Stamp' Function. the display is dark on the screen any sugesstions.
Sep 13, 2008 | Canon PowerShot A620 Digital Camera
Canon PowerShot a620
Hey nanasandy,
This is a common error message for many Canon camera models. It is most often caused by the lens getting stuck by either damage to the lens mechanism, or something got stuck in the lens (i.e. sand). One thing you could try is blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens mechanism. If this doesn't work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 25, 2008 | Canon PowerShot A80 Digital Camera
Help??
Apr 15, 2008 | Canon PowerShot A620 Digital Camera
How do you replace the lens cover for the Canon A620.
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 25, 2008 | Canon PowerShot A620 Digital Camera
My PowerShot A620 lens isn't working
Don't even try unless you know what you are doing - you can get a nasty belt off a charged flash capacitor (around 300volts) - the lens is more than likely clogged up with sand, this will wear the sliding tracks in the zoom very quickly and will render it useless.
You can buy new lens assemblies (Colchester Camera Repairs) but the cost will be high, around £80.00 just for the part.
Jan 01, 2008 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
