2005 Chevrolet Colorado Logo
Posted on Jun 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 chevy colorado whole frnt left side lights
2005 chevy colorado whole frnt left side lights are out and the interier signal blinks quick
Anonymous
Level 3:
  • Master 553 Answers
  • Posted on Jun 26, 2010
Anonymous
Master
Level 3:
Answers
553
Questions
0
Helped
222112
Points
1655
The inside light is blinking quickly because the front blinker light is out. I'm afraid that without more info I can't tell you why the lights are out.
3helpful
2answers
2007 chevy impala brake light and left turn signal not working
Fast flashing dash signals mean there is a bulb issue-DEFINATELY!
Does a 2005 Chevy Colorado have a turn signal flashing unit/relay? The right turn signal lamp illuminates when the brake pedal is pushed.
Sounds like your tail light board may be shorted,switch the board to the other side to see if the problem follows the board or stays on that side if so it could be a faulty turn signal switch.
2answers
I have a 2005 Chevy Colorado. The right rear passenger tail light will not come on, I have changed bulbs, and I have changed the entire lense assembly.Everytime you put your foot on the brake the right...
I have this exact same issue with my 05 Colorado and its so annyoying (not to mention unsafe)... I thought it was just the blub- becuase in my case my signal is no loger blinking. My break light still works, as does my parking light...
Any thoughts as to why this is happening?
Please HELP!!!
2helpful
2005 Chevy Colorado edit
If you put the tail gate down, there is 2 screw (phillips) that holds the tail light in place. Remove them & you can twist the bulb out. Thats it, put back together in reverse. Hope this helps.
2answers
Have a 2005 chevy colorado, i installed a four way harness exactly how the directions say, but when i connect the trailor only the right and left turn signal and taillights work. No break lights.
On the truck, are the turn signals and the brake lights using the same bulb, if the brake lights are using a different bulb the trailer might not work withe the truck if it only has a 4 wire plug, might have to add brake lights to the trailer and use a 5 wire plug, yes this means rewiring the trailer and adding lights
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
