Question about Nintendo DS Console
Nintendo DS lite
I have just repaired a cracked hinge in a Nintendo DS and soldered a new power switch on to the motherboard but now the speakers don't work. The headphones are fine and I checked for broken wires conecting the speakers to the top screen ribon and all looked ok. Could it be a mis aligned ribbon? Everything else works fine.
Ive had that problem before, all i did was turn it off and on several times then it worked
Posted on May 11, 2008
You should get it fixed
Posted on May 09, 2008
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
My nintendo ds lite stopped working but does charge
The LCD screens may be dead. Ask a mechanic to change the screens.
Or maybe it is about the hinge. the cables may be damaged.
Did you spill anything on the DS??
Mar 12, 2009 | Nintendo DS Lite Console
Nintendo DS Lite dropped in puddle breifly, speakers don't work
Well you do know the ribbon cable that connects the two screens is in the left hinge right? You will need to get it repaired eventualy. You many need to check if the ribbon cable is damaged in any way, if it is you will need to repair it or get it repaired. If you choose to do it yourself i'de suggest following this guide. Good Luck!
Jan 07, 2009 | Nintendo DS Lite Console
Nintendo ds lite has a broken hinge
You can buy a new plastic housing for your DS lite on many different sites. Some are great quality. If the DS still works (despite the broken hinge) it makes sense to replace the housing.
You should be able to find enough videos on youtube to learn how to disassembe the DS and not do any harm. Make sure that you buy a tri-wing screwdriver (also called a nintendo screwdriver).
Hope this helps
Dec 23, 2008 | Nintendo DS Lite Console
I have a Nintendo DS Lite that needs a new housing. It works fine, just the rounded hinge on the right is bent and cracked because it was dropped. Can a local repair shop put a new housing on, or do I...
Go to this page on Nintendo's website. Regardless of your warranty status, they will offer repair options.
"Nintendo DS Lite - Plastic Housing and Hinge Issues
If your Nintendo DS is experiencing issues with the plastic housing (such as a cracked hinge), please contact our Consumer Service Department at 1-800-255-3700 so that we may provide you with repair options."
Nov 30, 2008 | Nintendo Computers & Internet
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
Right controler on back of nintendo ds lite doesn't work
you probably disconnected a wire on the inside
Jan 05, 2008 | Nintendo DS Console
Nintendo ds hinge fix
Well, you can buy a hinge from a lot of places, but the wire that broke, you are going to have to try and fix the wire, get it connected again so that it will work. The only other solution is that you will have to send it in to get fixed.
Aug 08, 2007 | Nintendo DS Console
NINTENDO DS FELL 2 FEET AND WHEN I CHECKED IT THE TOP SCREEN WAS CRACKED IN THE BACK AND CANT SEE HALF THE SCREEN CAUSE OF THE CRACKS SO I NEED TO NOW IF YOU GUYS CAN FIX THE SCREEN OR KNOW A PLACE THAT...
DONT ATTEMPT TO REPLACE THE TOP SCREEN ON THE DS LITE. It is easy to replace it on the original ds, But the ds lite requires you to re-soilder the 4 speaker cables into the top screen's video ribbon cable.
Aug 03, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
135 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
