Question about Sony SA-WM500 Subwoofer
I believe an amplifier problem
Right before the subwoofer stopped working it made a rattling sound that resembled more of a problem regarding the amplifier rather than the actual speaker (I cant explain the sound too well). Ever since it has stopped working, nothing appears to be wrong with the speaker cosmetically (the cone is not damaged or stiff). When I press the button, the green LED still lights up. However, I do not hear the actual speaker "turning on" or "engaging" like it used to about three to five seconds after pressing the button. Nothing happens when I run sound through it. Any suggestions?
  • maximaboy Jun 02, 2008
    I have the same exact problem. Did you find a resolution?
  • Anonymous Sep 25, 2008
    My Subwoofer make a fine noise when is on for 4 hours and in the morning still make that rattle sound
    Problem Solver:
  • 7 Answers
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new. If yougo here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.htmlyou can find a free service manual that has the wiring schematics forthe amp. Hope this helps!
Posted on Jul 13, 2008
MY SUBWOOFER IS MAKING A RATTLING SOUND
Posted on Sep 25, 2008
My Sunfire MKll is making a popping/rattling sound during some low frequency notes, the sound is coming from the left woofer when facing the amplifier board ( its the softer woofer of the two, but...
The passive radiators on those are notorious for coming apart inside and making a knocking noise. You can sometimes glue it back together but youll have to remove the driver from the cabinet.
Jul 30, 2012 | Sunfire True Sub MK II Subwoofer
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
One of my kicker cvrs rattle really loud at high volumes
It could be the foam edging where the speaker meets the edge of the cone. Rubber works better than foam, and I believe kicker uses foam for this model. Check for any missing screws because sometimes air leaks make that sound you hear. also try turning down the amp a little bit
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
When i play certain bass, like mainly highs, but not all highs, my speaker seems to rattle. no im not an idiot. i know subwoofers rattle stuff when you have them on. i know almost all there is to know...
It is possible to overdrive a speaker beyond what it can handle.
DO NOT BELIEVE the spec sheets regarding power and capabilty, especially those for automobile amps and speakers.
If the cone moves too far, the voice coil leaves the active area of the magnetic field and the speaker will "rattle".
The speaker AND its enclosure may be resonating at particular frequencies.
If these things are happening, you will permanently damage the speakers.
Jul 29, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
Install subs on back doors on a 95 suburban
Install Dynamat. That should stop the rattling and distortion. the distortion is from the door vibrating the sound waves and messing the sound molecules up before they reach your ears. stopping the vibration should stop the distortion.
Jan 20, 2009 | Insignia 600W Bridgeable Amplifier with...
NO SOUND
check to see if the rca's have been disconnected from the amplifier or behind the head unit. if ok, thake a power meter and measure speaker outputs on the amplifier to see if voltage is present. can also check resistance on subwoofers to see if they are blown.
Jul 12, 2008 | Car Audio & Video
Guitar amplifier sound
HI thecross
What model Marshall have you got?
regards
robotek
Jun 04, 2008 | Audio Players & Recorders
Sony SA-WM500 Subwoofer Logo
522 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
