Tv powers up but no picture no menu no switching between sources Olevia 532-B12 is the model
    Problem Solver:
  • 6 Answers
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Posted on May 17, 2009
  • geolemon Jun 15, 2009
    Apparently there's no messages here...
    Email me at "geolemon at yahoo dot com" if you have a 532-B12 that isn't working but has a good screen.
No power cant find the source
Yes, tv should be Power On to find any video source and if tv is Off for some reason, it is not possible to switch any source.
How old is your tv and does it show any display on its screen or Menu pop up when you press menu button on remote?
Aug 24, 2010 | Hitachi Televison & Video
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
Tv picture wont turn on
Press the menu button if the menu does not come up then the issue is with the tv. If the menu does come up , try a second source such as a dvd player or a game system. you may need to change the channel on the tv or the input to get video and sound.
May 06, 2010 | Panasonic PT-56DLX25 56" HDTV
Convergence off Olevia Lt23 after replacing capacitors
Hi marlene
I assume that your friend replaced those capacitors because the tv was dead(no power).
And as far as i can see , your tv doesn`t have a usb port, just a service port that is not user friendly.
If you can give me a full description of what the picture looks like it would be very helpful for me to assist you.
But first go to the "screen"function menu and see if you can adjust the screen ratio.
Also if you can tell me what symptoms your tv had before any repair was made.
Mar 01, 2010 | Syntax Televison & Video
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Hi i have a olevia model 532 B12 television out of my trailer and i need a stand for it how do i get one ???
Hi
The first option would be to contact Oevia direct nad see if they can supply you with one however this may be quite expensive and difficult to do.
The second option would be to buy any VESA standard mount for your TV and use this option, You can check if your TV takes this type of mount by looking on the back, there will be 4 holes around 5" apart where the mount will bolt into, you can get either cantilever wall mounts or if you look on ebay or the likes of you can usualy find secondhand VESA mounts for sale.
Hope this helps
Dec 09, 2009 | Syntax Televison & Video
OLEVIA 532-B12 need video card
If it's a simple replacable part, it might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact. I think that Sears repair person might be making it sound a little more modular than it really is.  If he's talking about replacing the mainboard of the TV (which IS a video board), that's basically "the guts" of the TV, and not a readily available part like a power cord, back side connectors.
May 07, 2009 | Televison & Video
No sound or picture but menu comes up
Check video source like DVD Player has power, check connecting cords, cable connections etc.
when TV gives menu on screen that means TV is fine and problem could be hooked video signal items.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Olevia lct50hv
check your ballsit power supply, this is the part the light bulb goes into. Check light engine
Feb 19, 2008 | Syntax Olevia 50" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
