Question about Dishwashers
Our Kitchenaide dishwasher is approximately 4 years old, all my glass ware comes out cloudy and I have to wash it by hand.
  • 135 Answers
Your using too much soap. Use 2-3 tespoons of name brand powder soap. Premeasured gel packs or tablets are too much soap as well. Cut them in half if u are using those. You can run a cycle with 5-6 cups of white vinegar with no soap or dishes to clean the soap residue from inside the dishwasher.
Posted on Apr 15, 2008
Glasses look awful after being washed, maybe I need maintanance
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. After that it is recommended to use a little vinegar in each cycle to maintain the clarity of the glass.
Feb 25, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Eight years old and suddenly dishes and glasses are not being cleaned and result is film on everything
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 05, 2011 | DCS DW-24-SS Built-in Dishwasher
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Some of our dishes in the top and bottom rack are showing a white film, especially on plasticware and the outside of pots, pans, ceramic or regular glasses. Also some glasses on top rack , but not all,...
Nov 19, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Suddenly my asko dishwasher is not cleaning my dishes effectivelyl-- there are cloudy smears all over my glass ware & cutlery-- I use a rinsing agent, but it makes it all worse.
soak the cloudy glass ware in white vinegar for at least 5 minutes. If you can remove it, it could be hard water. You need to adjust your detergent amount. Have you changed detergents ? If so use a high quality brand.
If vinegar doesn't remove the smears, it is probably etching that is caused by hard water, too hot water or prerinsing
Sep 17, 2010 | Asko Dishwashers
Whirlpool Dishwasher---All Dishes Finish With Cloudy Film
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Plastics are coming out very white cloudy when they never have before
Plastic ware and even glass will get "etched" and look cloudy from use and from dishwashers.. The "clouding" effect could allso be causeed if the water is soft (mean not hard water) and if there is to much soap - it wont runs off properly..
Feb 03, 2010 | Dishwashers
Dishwashers Logo
225 people viewed this question
Top Dishwashers Experts
