Evoluent (VM2-LBB) Mouse Logo
Posted on Jun 26, 2010
I bought a evoluent vertical mouse. the right click does not work. I am uisng Microsoft XP version 2002, professional. I installed the driver. But I did not delete othr mouse drivers, because I do not know what they are called or how to find them.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
445
Points
Does the third button act as a right click?
tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
1helpful
Evoluent mouse
If there are no screws on bottom then usually it snaps apart. Look for a line or crease at bottom plate (where they are joined) and use a sharp edge like a small knife and gently try to unsnap bottom plate from mouse housing.
My Evoluent 4 mouse doesn't work with WIndows 7
win 7 driver has stopped working
uninstal the driver for the mouse , find the web site for the manufacturer of the mouse , get the download for that model and compatibility with win 7 , down load and run
win 7 os is no longer supported by Microsoft so driver bugs and other glitches are not being fixed
3helpful
2answers
Hp laserjet M1005 driver how can download
Normal 0
You can download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
1helpful
6answers
Dear sir, i have windows xp professional, service pack-2 version 2002, 0504 part no:-x10-59871. i need product key.
after logged in go to control panel , add and remove progams
tick on the show updates
now
u can see when the genuine notification is installed on your computer
restore the system to the erlier date
next login genuine notification not display at the time of login\
1helpful
My computer is installed with XP Professional and my new Microsoft Mobile Mouse 3000 will not work. Why?
Make sure the batteries are new or charged.
To activate the mouse press the connect button on the receiver and look underneath the mouse for the connect button and press that.
All you have to do then is right click on the mouse to activate it.
Regards.
My evoluent vertical mouse 3 freezes
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the CD Software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
4answers
Microsoft Office Trial Version and Upgrade
I bought an upgrade version and it doesn't work. What should I do?
First, please confirm you meet the qualifying criteria for an upgrade purchase. To qualify for an upgrade you must have a valid license for one of the following products: Office Standard Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Office 2000-2007 (any program or suite), Office XP (any suite) Office Small Business Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft OfficeXP (any suite) Office Professional Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft Office XP (any suite) Project Professional Microsoft® Office Project Professional 2000-2003; Project Standard 2000-2007 Visio Professional Microsoft® Office Visio® Professional 2000-2003; Microsoft Office Visio Standard 2000-2007 Visio Standard Microsoft® Office Visio® Standard 2000-2003; Microsoft® Office Visio® Professional 2000-2003 Live Groove Microsoft® Office Live Groove® 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Publisher Microsoft® Office Publisher 2000-2003; Microsoft Publisher Deluxe 2000; Microsoft Publisher with Digital Imaging 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Small Business Accounting/Office Accounting Professional Microsoft® Office Small Business Accounting®2006; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite)
Found here:
http://us20.trymicrosoftoffice.com/faq.aspx?culture=en-US
Mouse problem
usally xp dosent need mouse to get installed . windows xp i sdesigned for supporting all human interface dvices like keyboard and mouse .. normal xp other than service pack 2 need some drivers . check whether the set up program is designed for windows xp . if not right click propertiess of .exe file go to comaptability there u acn find run this program comaptabile for 98 ,nt , me etc sect the driver version and install
Top Evoluent Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Evoluent Computer and Internet Expert? Answer questions, earn points and help others
