Question about Fossil CH2332 Wrist Watch
Band Need to remove some links to shorten band can you help?
  • Adidias Apr 16, 2008
    I bought my son a Fossil watch (FS4314), and I can't see how to remove some links of the band. Any help?
    President:
  • 2,501 Answers
If it not obvious how the hinge pins are removed, then I suggest that you go to a watch shop to do it for you.
Posted on Dec 27, 2009
Shorten wrist band on a RADO CERAMICA JUBILE mens watch
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
Feb 11, 2011 | Watches
How do I shorten my Ice watch strap?
mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
Jul 17, 2010 | Watches
I need to shorten the metal link watch band of my Casio Model 2747 watch.
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Dec 31, 2009 | Casio Watches
Need to shorten the flex band on one button watch
If you have never done this you will likely break the first one you try; don't be discouraged.
Call some jewelry stores to see if there is anyone competent in sizing expansion bands (most likely an independant jeweler is your best bet as they only hire experienced jewelry professionals where as most chains they just hire whoever will work for the least money and no experience required).
If you are set on frustrating yourself here's how you size it.
1. fold down top and bottom tabs on both sides of band with a flathead screwdriver or similar.
2. move down the bracelet the number of links you wish to remove and fold down the top and bottom tabs there as well.
3. remove links (they will slide out)
4. reconnect the band with the small "U" shaped springs using a tweezers.
5. Fold down the metal tabs to enclose the springs.
6. lightly tap with hammer to make sure the tabs are flush and secure
Oct 17, 2009 | Avalon Ezc Low Vision Talking , Gold Tone...
Shorten watch band
For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links.
spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers.
Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side.
Now count down the number of links you want to remove and perform the task again.
*Remember that you must do it the exact same way on each side or the band will not go back together.
Once you have the correct number of links out the band will go back together the same way you took it apart.
When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
Sep 17, 2009 | Timex 27191 Wristwatch
I can not get the watch band to fit my wrist. How do i shorten the band
If it is a metal band there are links in the side of teh band that you can remove. If all teh removable links are gone you may need to change the band into a smaller one. And there are little pins by the watch you can do that as well. I recommend taking to a jewelry repair shop. Some jewelry store do repairs as well, and may have parts you need for this as well as the tools.
Dec 12, 2008 | Watches
Need to shorten a band
you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
Jun 24, 2008 | gossip Watches
Item number L12445 band adjustment
How do I shorten the links on a woman's eco drive citizens watch band?
Apr 22, 2008 | Watches
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Fossil CH2332 Wrist Watch Logo
175 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
