Question about Hitachi DV-P745U DVD Player
Power does not stay on.
Have to reset player (disconnect plug) and then when I push pwr button on remote or on the unit, it stays on for about 3 or 4 seconds and then shuts off. It then has to be reset again. Once reset and you push open/close button, the tray will come out and the unit will stay on until tray is closed with or without a disc and then shuts off again. ? ? ?
    Scholar:
  • 170 Answers
Check and replace caps in the power supply as they maybe leaking causing the voltages thought the unit to be unstable.
Posted on Apr 15, 2008
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I lost my code sheet. how do i get a new one.
Try to do this:
Guide to Programming the Remote
Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
Using Code Search:
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
SOURCE
Sep 29, 2010 | Innovage Jumbo Remote Control
Will not power on-- batteries are new- if pwr
Hi:
I was using one of these for the last 8 months, and mine did the same thing, I would push power and the unit will just blink the lights then shut off, But if I hold the power button the light will stay on until the button was released, so I contacted Solo Tech support and they told me the system control board was bad, and in order to get a new board I had to be an authorized servicer for then, I found the board online and the price for the board exceded the price I paid for it. So i deemed it necessary to just purchase a new Scanner....
Dec 27, 2009 | Solo S2 Radar Detector
Wrt54g diag light stays on and unit wont start working.
It is probably dead, but there are a couple of things you can try:
1] Power the router and hold the RESET button for 30 seconds, then remove the power and try again.
2] Visit this site (it has very clear instructions on how to physically restore the firmware.... http://www.freewebs.com/wrt54grevival/wrt54grevial.htm.html#beginner
Mar 13, 2009 | Linksys Wireless-G WRT54G Router
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Yp-k3 samsung Mp3 Screen Froze On "Remove Cable"
My daughter had a similar problem - she was frozen at the power off screen. On closer inspection, at the bottom of the K3 on the back of the unit is a reset button (you will need a pin or paper clip to reset it). Pushed a pin in for a few seconds, reset, all was OK.
Aug 21, 2008 | Samsung YP-K3 MP3 Player
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Unit Powers on but Screen is not working.
I had the same problem before. I thought the mechanic broke my radio. The power button will not work on the radio, right? I couldn't turn it on or off, but the blue lights stayed on all the time. What I found out is that I had to put a new battery in my remote because it died at the exact same time. Crazy, huh? But anyways, you have to use the power button on the remote or else it will stay black forever. Once you turn the unit on with the remote, it will prompt you to enter your password. Like guest said before, if you didn't set your password before, then the default code is 0000. I hope you get that thing working!! -kev
Sep 24, 2006 | Panasonic CQ-VD7001U Car DVD Player
Hitachi DV-P745U DVD Player Logo
130 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
