Question about Zebra LP 2844-Z Thermal Label Printer
Alignment of print with Labels
I use the label printer with the regular labels for this machine. I cannot get the printer to remain within the label margins. Any suggestions?
Sid C.
  • patch_68 Apr 15, 2008
    This is for the TLP 2844-Z
    Problem Solver:
  • 10 Answers
Perform a media calibration as follows: -
Turn the printer off
Press and hold the green button and turn on the printer.
When the red flashes 3-4 times release the button and the printer shoould perform a calibration, then try printing again. Any futher problem with this contact Lancer labels
Posted on May 15, 2009
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
May 17, 2009 | Toshiba TEC B-452 Thermal Label Printer
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Different label alignment on different printers
Right click on the printer icon and choose properties
Feb 03, 2009 | Kyocera Mita FS 1010 Laser Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Skipping 1 mm (regular intervals) while printing labels
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
Nov 02, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
1,430 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
