Question about Car Audio & Video
Needs installation instructions and t.v code - Car Audio & Video
  • 1 more comment
  • head6 Apr 15, 2008
    jensen vm9311ts
    there isn't any codes for jensen vm9311ts
    OK, CHECK IT OUT
  • 19,396 Answers
Which is your make and model?
Posted on Apr 15, 2008
I need a code for the alpine 7521
Request the code from Alpine. It should have been included in the original installation instructions.
Dec 11, 2017 | Alpine Car Audio & Video
Phillips codes
Download a regional code *.iso file (search google, there are many), burn it to a dvd and place it in the machine to install. If it does not install automatically check the manual for install instructions.
Dec 15, 2013 | Sony DVP-SR500H DVD Player
Instructions to change the code
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Feb 22, 2012 | Weiser Lock Powerbolt 1000 Lock
Reset new codes and old existing codes won't erase,the original code from last year still works, even after installing 2 new codes
Here's the link to the online instructions:
http://www.weiserlock.com/PDFS/instructions/Electronics/Powerbolt.pdf
Programming instructions are on page 6. Notice that allowing too much time between inputs will be a problem.
If you cannot successfully override your existing codes, contact Weiserlock Customer service:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
A note about PDF files: You will need adobe Reader or equivalent installed if you are unable to view the instructions. http://get.adobe.com/reader/
Nov 03, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
I do not have the programming code, how can i change code
Here is a link to the specific installation instructions where you will find the programming instructions for your lock:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It's a PDF document, which will require that you have Adobe Reader installed to properly view it.
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions (mentioned above), as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Apr 22, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I need to programming instructions for this lock. it has a keypad on it and I do not have the instructions for it.
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
Complete installation & programming instructions can be found here:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Videos for installing and programming can be found on this page:
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Good luck--and please provide feedback if this helps!
Nov 01, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Need to reset codes and need instructions, were can I download them to print?
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
Sep 23, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Ntl box
To enter the codes you follow the instructions here.
Nov 29, 2008 | Computers & Internet
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
