Question about Hotpoint Aquarius WF215 Front Load Washer
Re:hotpoint aquarius wf740
Hi, the stooopid machine keeps stopping at 1 minute and i have to turn it to another wash and it then rinses, spins, then fills up over and over again. When it eventually decides to let me open the door the clothes are still soaking. I tried to put some washing machine cleaner/descaler stuff thru a wash but when that stopped i could see loads of water in the bottom of the drum. I think there must be a blockage somewhere but I haven't a clue where to look! Could anyone please help a damsel in distress??
    Genius:
  • 1,073 Answers
Check the pump circuit
Posted on Apr 16, 2008
WF740 Aquarius washing machine keeps going through a Test cycle. Cannot get it to wash?
Turn off the appliance at the mains, hold on & start buttons down then turn back on at mains and hold until dOFF appears should now be back the normal.
Oct 20, 2014 | Hotpoint Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Programme not moving on
This is not something like a belt or a motor then...It's probably the Logic in the control system.
Your best bet is have a hotpoint engineer diagnose it - and fit a new control module. To buy from hotpoint they range from 70 to 90 Sterling.
In england the call out is £90 and they actually don't charge for parts if the machine less than 5 years old.
Feb 25, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF215 Front Load Washer Logo
151 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
