Question about Kenmore 24032\24036 Top Load Washer
Spinning problem on the washer
My Kenmore washer does not spin and hence the clothes come out without being drained properly
  • Anonymous May 12, 2008
    rebuilt gearcase on 80 series kenmore direct drive washer. agitates fine but does not spin clothes to rid of excess water. spins intermittent.
  • Anonymous May 14, 2008
    kenmore clothes washer model 110 26692503 won't spin clothes are sogging wet when taken out
    New Friend:
Good chance it is a timer. this model you can take apart the timer and file down any burnt contacts. this should work for a while until you get a new timer
Posted on Mar 07, 2013
  • 868 Answers
Check the lid switch.Try this loosen the 3  trans . bolts about a quarter inch and try it.
Posted on May 22, 2008
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
Drain & Spin issue
Have you checked your water pump? Sometimes this is an issue of the strainer being plugged as well. Do you get any flashing error messages on teh screen?
Jan 14, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
114 people viewed this question
Sal De
fordexpert
Robert Rankin
