Question about Vacuums
Sparks from motor when turned on - Vacuums
  • 2 more comments
  • Anonymous May 07, 2008
    where can I get brushes for the motor on my Sharp EC-12twt4 vacuum cleaner
  • Anonymous Jun 25, 2008
    end of wire came out of brush. where do i find new brushes or is it part of motor?
  • Anonymous Mar 21, 2009
    I'm having the same problem.. Sparks are seen coming from the motor when I turn it on.. Smells like metal burning..
    Anyone fix one of these.. Is it worth fixing?
  • Anonymous Mar 25, 2009
    My Hoover sparks and looses power when turned on.
There's a short circuit on the motor armature.. needs replacement but it can be repaired depending on the problem.
Posted on Jan 02, 2009
No, do not replace the motor, the copper wire just melted off, correct from right on the metal brushing on the end, correct?
Geta welder or a mig welder or just a welder guy to weld , he will weld for maybe just $10-$20 dollars, the $59 dollars plus shipping on the motor will be about 75-80 dollars....jeeze the motor is good, just one of the brushings are bad. Have it tack welded....easy quick place back in....
Posted on Aug 07, 2008
    President:
  • 1,673 Answers
Either the carbon motor brushes are bad or the motor armature is bad. May have to replace the motor.
Posted on Apr 15, 2008
Spark caused vaccum to turn off
Some vacuums have a reset button you can push. Some have a fuse in the power line that may have blown. You will have to follow the power all the way through the vacuum checking the voltage at each switch, connection, etc. I often unhook the power & neutral wires from the motor and hook up a power cord with connectors on the end directly to the motor to make sure the motor is good. You must be very knowledgable with motors, switches, electrical testing, etc. If not this repair is best left to a professional.
Mar 03, 2014 | Dirt Devil Vacuums
Motor issues
A faint burnt plastic smell is actually normal for these when brand new, but that normally disappears after a week or so. As for sparks, a thin trail of blue sparks trailing along the commutator (the uppermost part of the motor that can be seen rotating) is normal. However, if there are blue, orange sparks flying out of it its toast. The motor is dying in that machine.
Nov 23, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Spinbrush is very loud, barely sprays, spraks flew out the side. It is only 6 months old.
Hope you kept your receipt! That's a warranty item. Your motor is making the sparks. Go to hoovers website find the nearest service center and take the machine and your receipt to them. You'll get a new motor, installed, at no charge because they have a 1 year warranty.
Jan 18, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
Motor is sparking and smells like burning rubber. When it first happened I thought the vacuum had something jamming the beater bar. That was the smell it had, like when the belt gets burned. But when...
from sound and description most possible is motor is burnt up sparks usually mean metal on metal either bearing or bushings went on motor if u can jiggle the shaft thats bearing if u rotate the shaft by hand and feel and or hear rough grinding the brushes are damaged and the (windings)are also would need to replace motor oreck has a costumer service 800 989 3535 number give them a call not always but some times they will ship a replacement part for free
Nov 22, 2009 | Oreck Vacuums
Its spark at the back of the motor when its turn on.
yep very common of dyson vacs you will have to get the motor replaced not an easy job to do you might if you dowant to give it a go go on to youtube n search for fit dyson motor that will show how its done good luck
Oct 05, 2009 | Dyson DC14 All floors Bagless Upright...
My hoover dual v steamvac make loud noise and sparks
Be careful. This could be a shorted wire inside where the motor is. If there is sparks , something is exposed and touching. The motor also may be ready to give out. Unless your daring enough to open the whole thing up I would bring it to a shop or replace it.
Jul 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Blue sparks from motor stopped working
either cord shorted out or switch failed would replace cord first if that doesn"t work probably have to take into repair shop
Jul 04, 2009 | Kirby Vacuums
Motor
you have it right either the motor is going out or water got in there causing it to spark and smell.sorry.lease leave feedback...pete
Apr 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dyson dc07 motor sparks
Hi.
I think you are looking at replacing the motor with a new one.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
650 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
