Question about Conair Compact Garment Steamer Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
  • 3 more comments
  • Anonymous May 29, 2008
    same problem... no instruction manual came with it either...
  • streaterc Aug 08, 2008
    Same problem here too! I bought mine at a garage sale for $2 new in box but it doesn't work. I have searched online also for a manual to download or some help, but haven't found anything. Glad I didn't pay full price.
  • kime2439 Sep 18, 2008
    I bought one from Big lots, I guess I should have known better, but i have the same problem, it gets really hot, but no steam comes out.
  • tpgmbg Dec 13, 2008
    instruction were not included with the purchase - steam cleaner conair sc20. whre can i find manual.
  • hismusicnme Mar 24, 2009
    Thank You "cisheolawson", however after I have taken this machine apart, and there are Not any "rings" to get clogged. Am unsure what it is you are referring to.
    Problem Solver:
  • 15 Answers
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Posted on Nov 05, 2008
  • laura_b1215
    laura_b1215 Apr 28, 2009
    It is impossible to find online link to a user manual for sc20, but if you call Conair at 800-326-6247 and ask for it they will email you the pdf file. Got this information from www.HandBookLive.com
I have a steam cleaner sc 20 conair and it heats up and the ready lite goes off but when I push the on button it doesnt come on at all
Posted on Jul 25, 2011
Use distelled water and check the rings where the spray comes out they can be clogged. You have to turn the switch on and give it time to heat up. I own one for 4 years and works wonderful.
Posted on Dec 06, 2008
Just bought the conair extreme steam, won't work, where is the steam reset button? Please help lol
It probably does not have a reset button. It is defective. Just return the item back to the store for a new replacement or refund.
Aug 04, 2015 | Conair Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
LOW WATER LIGHT stays on when water tank is full and no steam is produced.
Check the steam holes at bottom to see if holes is pluged with caculm build up that plug holes. To clean holes us calcum cleaner. Use decression . Use distalled water. Not tap water. There is probably a float inside of tank. Deposit calcum probably has stuck it. This is dependent on the brand and how old it is.
Mar 25, 2010 | Conair Compact Garment Steamer Iron
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Water
Generaly there is a hole somewhere.. have you tried looking in the instructions?
most of the time is in the front close to the steam buttons.
Hope it helps.
R.
Jan 02, 2008 | Conair GS16 Iron
Burst of Steam
if no steam at all, there is most likely a small port where some particles have clogged...fill it with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 23, 2007 | Conair DPP4000 Iron
Conair Compact Garment Steamer Iron Logo
1,746 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
