Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon IR3300 would not scan when use the
I just bought a Canon IR3300 (used). I was able to network this printer/copier, however I was not able to get the copier to scan "online". I downloan the "Scan Gear" software from Canon, but it was unable to discover my printer in the network. I even tried to put in the IP address, it still was not able to detect the printer. Please help.
  • yogesh vasudeva Mar 09, 2009
    I had putted ip address but unable to print through network but when i send the print to LPT port the machine print and more ovber i can scan the documents through scan gear software. Please help.
  • Anonymous Mar 19, 2014
    I have got same this printer Canon IR3300, could you please what will be the right gear (link to it) for this printer to be able to scan ?
    Sniper:
  • 89 Answers
Simmo75 you are wrong. The IR2200 series (IR2200, 2800 and 3300) can pull scan using Network ScanGear Tool if it's networked whereas with optional accessories the 2200 has more options such as scan to email, smb etc.
IP address for computer and copier must be similar e.g. if one is 192.168.1.23, the other must have the first three out of four numbers being the same, with the other different. Subnet masks must be exactly the same for all four numbers e.g. 255.255.255.0
Other things to try: Temporarily Disable Firewall. If this fixes problem add IP of copier to trusted list and make Network ScanGear a Trusted application.
Posted on Jul 17, 2009
  • mdgm Jul 17, 2009
    Oops I meant 2200i for more options.
Give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Posted on Apr 19, 2008
    Problem Solver:
  • 10 Answers
If it is not an iR2200i with the i, then u cant scan
Posted on May 17, 2008
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I want canon ir3300 model scan drivers and how use instructions manual setup window xp os. color and b/w mode.please request send scan drivers to my mail
Does your IR3300 have the network kit installed?
If so you can use Canon Network ScanGear Tool v2.30 (you can find the download on canon websites e.g. http://software.canon-europe.com/software/0040589.asp?model=). The IR3300 is a B&W copier with B&W scanning, so don't use the colour version of the tool.
The tool comes with a manual on how to use it. I recommend using it with Adobe Acrobat.
Jun 16, 2011 | Canon imageRUNNER 2200
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I have ir3300 how can scan as pdf formate? please advice me
my canon 3300 all in one printer (image runner) pdf files print very slowly
May 04, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How do i scan from canon iR3300
download the scan gear software & then u can use the scannerm
u can scan through adobe photoshop, ms office
Mar 20, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Printer keeps pausing itself!!
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Aug 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
2,263 people viewed this question
old marine
old marine
Corne Viljoen
