Question about Dell Inspiron E1405 Notebook
Dell Inspiron E1405 touchpad does not work
So my touchpad does not work, and it doesn't show up in the device manager. In addition, my keyboard does weird things, and the system speaker keeps beeping even if I have disabled it. What do I do?
  • 35 Answers
  • 191 Answers
Regarding touchpad log on to this link and download touchpad drivers
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
make sure you choose the operating system correct and install Input Device Drivers
you will find 3 options you have to download the third one
Dell - Driver Applies to: Dell Inspiron E1405 touchpad does not work - hiernest.gif Touchpad / Pointing Stick
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
if you are in United states call 1-800-624-9896
Posted on Jun 05, 2008
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Touchpad not in device manager
Hi There,
The touchpad will normally show up under input devices in device manager. If you don't see it listed, check to see if your touchpad has a manual on/off switch located on the laptop keyboard (sometimes under specialized function keys)
If a switch doesn't seem to be the issue, try reinstalling the drivers for the touchpad, which should be available on the toshiba website.
Aug 06, 2012 | Toshiba Satellite P105-S6197 Laptop
Unlock the mouse in dell inspiron m5030
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Dell Inspiron M5030 Laptop
    My Dell Inspiron M5030 Laptop Touchpad is not working at all. The settings could not load. What should I do to solve this problem?
    If the settings of the touchpad doesn't load, you need to reinstall or update the touchpad driver. You can go to "Device Manager" or Dell website and download an updated driver.
    Hope this helps.
    Jun 09, 2011 | Dell Inspiron M5030 Laptop
    Dell Inspiron e1405 bluetooth disabled
    If it doesn't show in device manager than it doesn't have a driver, you will have to reinstall, go to the link below, download and install, ALL, the correct files for your version BT, Bluetooth files there, that should fix it.
    http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_E1405&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
    Feb 26, 2010 | Dell Inspiron E1405 Notebook
    Have an Dell inspiron e1405 laptop. Screen is not
    Try new memory (RAM) or if the device has two memory module install turn the deviice off take one module out turn on
    If it does not work then
    Turn the device off take the second module out replace with the first module
    Turn the device on
    Jan 06, 2010 | Dell Inspiron E1405 Notebook
    How can I change the settings on my Dell Inspiron E1405 touchpad? I don't find "Mouse" or "Printers and Other Hardware" listed in the Control Panel. I want to speed up the movement of the touchpad but I...
    I think that the E1405 uses the Synaptics Touchpad, so the settings should be found under Start > Programs > Synaptics. However, if it is not there, then try C:\Program Files\Synaptics. The application that controls the settings should be found in one of those two places. Good luck!
    Oct 22, 2009 | Dell Inspiron E1405 Notebook
    Dell Inspiron E1405 Keyboard and touchpad stop responding when bootup gets to Windows password screen. Any ideas as to why? Thanks in advance.
    could be a problem with drivers. Try to start windows in safemode. To start in safemode keep pressing F8 imediattly after the laptops starts and will show up a screen, choose safe mode. If in safemode works use system resotre and restore to an earlier time when worked.
    Jul 18, 2009 | Dell Laptop Keyboard for Inspiron 500M
    Scrolling
    did it always have vista
    check settings for mouse in control panel
    also update driver in device manager
    Feb 01, 2009 | Dell F3534 Touchpad
    Dell Inspiron E1405 Notebook Logo
    1,327 people viewed this question
    Alun Cox
