I have an external drive (Canyon HDD25) which although i can see on the 'my computer' screen i keep getting errors stating it is not acessible. when trying to eject it as its USB i keep getting a message stating a program is still accessing it even though nothing is - unfortunately i have had to resort to just unplugging it now as it was slowing the PC down - any help/suggestions gratefully received
    Master:
  • 474 Answers
Sounds like it has bad data on it and it is screwing with Windows.
can you directly touch the hard Drive? I.E. is it in a case that has a USB adapted to it. If so, see if you can get to the Pins on it where the cables plug in, see if its set to SLAVE or MASTER or CABLE SELECT. Try it on SLAVE setting, you just pop off the little plastic thing called a JUMPER and set it to Slave, Most hard drives have a little picture or indicater that says what position to put it in.
Also, did it come with a CD that may have drivers for it, if so, try installing them.
The Data may be corupt also, which means you may have lost whatever is on it. as a last resort, try Formating it in windows.
good luck
Posted on Apr 15, 2008
When i start my computer the 1st error which i get is some thing like below \windows\system/config is corrupted or missing. after this take out my hard disk and whith the help of external drive i...
In order to provide any kind of meaningful help, please state what computer you are using (you can usually find the brand and model on the computer) as well as the Windows edition it is running (click on the start button, right click on 'Computer' and select 'Properties', the full name of the Windows edition will be at the top of the screen)
Dec 12, 2017 | Acer MF35 MP3 Player
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Aug 07, 2009 | Dell Inspiron Mini 9 Notebook
I turned on my external f drive this morning, after it worked fine last night. Now shows as local disk F. I cannot access it as it says F drive is not acessible error performing in page operation. I have...
The inpage operation error actually refers to an error going between the drive and your RAM. Try the drive on a different computer, if it works the problem may be in your RAM, if it doesn't the drive is corrupted and can't be read under normal circumstances.
If it does work, let me know and I'll link you to a memory diagnostic program to test your RAM. If it doesn't work on the other computer, let me know your Country, State and City and I can refer you to a nearby Data Recovery team.
Chris
Aug 06, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I have a seagate momentus 5400.3 160gb drive installed in a Thinkpad t60 laptop. It was working fine until after I had put it in hibernation, and subsequently tried to get back in (approximately 2 hours...
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
That should work ya long haired hippie. give me a shout this weekend, M.Y. (puff puff pass *****!)
Feb 21, 2009 | Seagate Momentus 5400.3 Hard Drive
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
"My Book" folder shuts down when I use it.
try to install the drive on another USB Port.
Cheers,
Apr 05, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
David Payne
David Payne
