Panasonic PT L501U Projector
The Lamp strikes then after 30 sec of so the lamp shuts off, and it goes into standby, but you cant get it out of standby.
  • starash Jun 04, 2008
    My panasonic projector goes into standby after 30-60 seconds (there is an orange light and then a red light). The projector has to be powered off and restareted (remote does not work). The projector then works fine for as many hours (even upto 12 hours). Lamp life used is only 10% and filter is also clean. The problem has now elevated gradually over a period of time wherein the projector has to be powered off 4 times.
  • 563 Answers
Hi there
Have you replaced the lamp ?
If you haven't - take out the lamp and chech for any irregularity on it - i.e. - discolouration , vein like looking marks ( black or white ) and also if the shape of the shaft is off.
If there is no visible damage it might be a faulty Ballast ( lamp's powersupply ) - especially if you cannot get it out of stanby once it has shut down.
Posted on Apr 17, 2008
Projector powers up, after 2 minutes image goes away, projector goes into cool down, then shuts off. why?
FAULT: lamp of your projector is faulty.
Experience: when lamp life is near to end and environment temperature is too low you are facing the same problem and if you are facing this problem in normal temperature then also lamp is faulty.
Sulotion: Just replace the projector lamp
Jan 07, 2011 | Panasonic PT-AX100U-EC DLP Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT L501u Replacement Lamp
panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
thats all the unit powers off & when u check the lamp counter , its shows 0
u r done!!!!!!
Jan 22, 2009 | Panasonic PT L501U Multimedia Projector
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Apr 17, 2008 | Office Equipment & Supplies
Ok , so the lamp is out then.
Before spending the money on a new Ballast.
Switch on the Projector while the top cover is off and check if all your fans are running.
The red light you see glowing on the Mainboard is quite normal.
Apr 17, 2008 | Epson EMP 720 Multimedia Projector
515 people viewed this question
