Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Load noise at start-up goes away after a minute, but there is no suction.
The roller turns, motor runs, but nothing gets into the cannister. I have cleared all the hoses and roller, but obviously there is limited suction. The exhause seems to be very hot to me. This thing is hard to take apart with a lot of screws, but frankly, unless there is something I don't see, I can't see anywhere it can be clogged. I was able to resolve a similar problem a while ago by cleaning the hepa and paper filters. Not this time. The machine is less than a year old.
  • Anonymous Aug 09, 2008
    same problem - bought vac 2/08. Its only six months later and the roller turns but no suction and a loud noise.
    President:
  • 1,673 Answers
If the brush roll and motor runs and sounds ok, then that is an indication of a clog, either in the hose or the dirt inlet down by the brush roll. You should have a years warranty on this, if you can't figure it out, then take it into Sears and get it repaired.
Posted on Apr 15, 2008
My dyson is not picking up, there is no suction its just blowing out warm air
Either the wind suction tunnels on top of the clear cannisters need to be cleaned out or the round foam filter between the bottom if the cannisters and the part with the roller bar is clogged.
Feb 26, 2018 | Dyson Vacuums
My Electrolux canister vac has no suction
You have a blockage somewhere in the unit from pickup to end of line where dirt is stored, only a blockage will cause this.
Dec 14, 2012 | Electrolux Vacuums
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Motor runs, but noisey, smells hot, brushes don't turn
First you need to check why the brushes are not turning, this could be due to a lack of suction, which means the smell of heat and excess noise is due to a faulty motor, this can also be tested simply by testing the units suction power.
A faulty motor is the most comon problem when it comes to smells of heat or 'ozone' as well as excessive noise. Good Luck.
Apr 12, 2010 | Hoover H3030 FloorMate SpinScrub 500...
My vacuum won't work-
sounds like the motor might have bit the dust.try this,unplug the vacuum and reach under where the brush rolle is and try to turn the roller by hand a few times,if you can't turnit then then the roller is jammed.take the belt off and then turn it on and see if it runs then.let the motor cool down first the motorguard might be keeping it from running.just let it cool down for about 20 minutes then try it
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
