This bad video drivers.
Restart the machine and repeatedly tap the F8 key. When you see the advanced boot menu appear choose safe mode.
You will see white text on screen that will stop on a system 32 driver, wait a minute and let it boot through.
Next, go do device manager and uninstall the display drivers.
Reboot the machine and it should boot into windows normally. You may have to reinstall the display drivers if they don't reinstall themselves.
Please post back if you need anymore help or advice.
Good luck.
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
