Question about RCA F32450 32" TV
RCA Model F32450
Our TV was working fine then shut off. We turned it back on and we do not receive a picture, only a high pitch sound when we plug it in. We cannot turn the sound down with the remote. We have to unplug the TV if we don't want to hear it. We're not sure if it would be worth it to get the TV repaired or just buy a new one. Any ideas?
Hot-replace and solder all leads to smt transformer.set should power up.also flyback may have shorted.rca has a repair kit for this set. all necessary parts.
Posted on May 12, 2008
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I have a RCA 32 TV made in 2002 It shuts off and turn and nothing
If its a F32450 it is prone to two parts failing.
I presume you mean you turn it on and it shuts right off.
A question? I you unplug it and plug it back in do you hear a high pitched whine for a moment or longer/
This model (along with some others) has a problem where the High voltage Transformer fails.
It will usually take a transistor with it. I have fixed dozens of them and usually just need to replace two parts:
Transformer is location LL05 and part number is 257805.
Transistor is location TL02 and part number is 237470---generic number is 2SC5148.
The giveaway is if someone checks the transistor and it is shorted--the transformer got it.
I can tell you a place on EBAY that will have both parts for less than 30 dollars total.
Clearly, I do not know if you can do this repair--I do this for a living and replacing both parts in this set takes less than 20 minutes.
Let me know if you have questions and I will try to help you---
If this helped you at all rate this solution as I do this here for free.
Dec 19, 2009 | RCA F32450 32" TV
Rca 32flascreen tv
high volatge transformer shorted...or component in hi E.
Jul 18, 2008 | RCA F32450 32" TV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
Shut off all of a sudden and makes this ringing sound
the most likly cause of this type of symptome is a shorted horizontal o/p transistor. typicall the part is 10 to 40 cdn. labour will depend on your local service shop rates. it takes abot 30min to 1h. to chane typically (if no problems are run into.). good luck.
Dec 24, 2006 | RCA F32450 32" TV
RCA F32450 32" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
