I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
  • 3,037 Answers
Change print settings
You can change print settings (such as paper size or type) from an application or the
printer driver. Changes made from an application take precedence over changes made
from the printer driver. However, after the application is closed, the settings return to the
defaults configured in the driver.
NOTE: To set print settings for all print jobs, make the changes in the printer driver.
For more information about the features of the Windows printer driver, see the online
help for the driver. For more information about printing from a specific application, see
the documentation that came with the application.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
NOTE: The settings that are available depend on the device model.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
Here is the user guide for your printer
http://static.tigerdirect.ca/pdf/HP-OfficeJet-J3680%20All-In-One-Printer-UserGuide.pdf
page 33 has information to change the print settings and page 28 shows how to load the envelopes
Check the index for anything you need help with or feel free to ask me, I am here to help
Thank you for using Fixya and Good Luck
Posted on Apr 15, 2008
  • 13,433 Answers
You need to change the paper size from the printing preferences in your pc, start -> controlpanel -> printer -> right click your printer -> printing preferences or properties if not there -> paper tab ->
select the correct size, and then when you are printing a document, you need to set the document properties correctly
if your printing the document sideways.. as in
then you need to set the properties from File menu -> page setup -> orientation to landscape
or as portrate if your printing it as
well I hope my text drawings are 'readable'
If you need more assistance let me know, I'm here to help
    Master:
  • 555 Answers
You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
Then pick "Landscape" in the print options menu when you go to print on the envelope.
Won't print envelopes
Envelopes may have to be fed individually through the single sheet feeder
Your word processing software may not have the correct parameters set for printing..
Jan 09, 2014 | HP Officejet Pro 8600 Premium
Envelope orientation wrong for # 10 envelopes
It may be necessary to go back to the initial set up and make sure landscape printing has been selected. Also, envelope feed orientation could be a factor.
Dec 21, 2013 | Mysoftware My MailList & AddressBook...
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
using office or other program, in page setup and also in printer setup you choose orientation and pick an envelope size of your choice. then go for it :)
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Pixma MP 970, how can I get manual
Here is the downlink for the Installable Manual. Download this where ever you chose so you can find it later if needed. Once it is downloaded, double click the file to unpack the data. Once that is unpacked click on Start and it will install to your Desktop. I found the below data from the manual. The manual looks very complete.
These instructions are directly from the Manual:
Printing an Envelope Printing an Envelope For details about how to load an envelope into the printer, see the user's manual.
2. Load the envelope in the printer.
When loading the envelope in the cassette, orient the envelope so that the flap is on the left and folded surface is facing up.
6. Click OK.
I hope this fixes you up and you get the manual downloaded. You many need to start here just in case and select the entry for the Manual in English.
Best Regards,
Worldvet
Jan 11, 2009 | Office Equipment & Supplies
How to load cartridge for a hp officejet j3600
hi
please find the step by step video for the installing printer cartridges for HP Officejet J3600
I hope this solves your query
Best of Luck
Jan 03, 2009 | Office Equipment & Supplies
Help
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
117 people viewed this question
jasbo
jasbo
