Question about Sharp Audio Players & Recorders
Turn table not going round on a Sharp VZ-1900E?
Please help as I have this problem too and can't see how to get into it to change the belt
Posted on Jun 11, 2011
I have a 2004 VZ 800 and the turn signals and hazard flashers have stopped working. Checked fuse and checks ok.
Did you check the flasher relay? Just like on a car there'll be a round or square tin flasher on or near the fuses, when operating it ticks on and off just like an automotive one
Aug 24, 2014 | 2004 Suzuki VZ 800 Marauder
How do i set the tax rate for Casio QT-6600?
go to PGM 3 then go to
1- Machine Feature
go to
9-Tax Table
go to
1- tax table 1
set tax rate to 5.0000
set Rounding to Round up
set singapore Rounding to Round up if you are not using the 1 cent anymore
set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose
2- Tax Table 2
repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
Jan 31, 2013 | Casio QT-6600 Cash Register Touchscreen...
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Do I need a coffee table?
I personally think that every living room needs a coffee table. It seems to tie the room together and serves a purpose for magazines, remotes, little snacks when you watch TV, etc. I just think they make a living room look finished. If you have kind I'll have to go with a round coffee table so that there are no sharp corners so your kids won't get hurt.
Jul 31, 2012 | Furniture
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
My sharp R-953 turn table turns slowly when you put some thing on it ,it stops turning
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 13, 2011 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel model number R-930ak + parts The plate inside does not spin sounds like a cheap plastic gear on the bottom is worn out and stripped. MAkes a clicking sound
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
For the model number you have listed, the part number is 46-841666-3.
You can purchase replacement parts at searspartsdirect.com.
The site also offers helpful exploded view diagrams to assist you in parts location/identification. The motor is listed at item 001-20 under the "Cabinet" heading. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: You also consider the turn table coupling, which is item 004-22. The underside of the coupling has a keyed slot that fits on to the turn table motor shaft. If the coupling becomes cracked, or if the keyed slot "rounds out", it may be slipping on the motor shaft and not turning.
Dec 17, 2009 | Sharp R-930AK Convection/Microwave Oven
Faulty turntable
Hi Roger It will need a new turn table belt. They are an odd size, but can generally be bought from a good spares part supplier. Let me know where you are and i will be able to steer you to a parts agent that can organise one for you. Thanks for using FixYa. A "fixya" rating will help my profile and create an incentive to get the parts source organised for you;)
regards
Graeme
Mar 15, 2008 | Audio Players & Recorders
169 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
