Question about LG WM-1832C Front Load Washer
Fabric pulls on gentle cycle
I have had this washer for 4 years. Just recently I have ruined several delicate shirts, both cotton and woven, washed in the cold/gentle cycle. I am so upset! What could be happening?
  • Kayrae Apr 28, 2008
    LG is offering to replace drum (under warranty)---drum is not being made any more (only 4 years old!)
  • 489 Answers
Check the inside of the drum to see if there is any loose vanes.  Then check the holes in the drum itself to see if there is any protruding metal shavings that is causing the problem.  There should be no rough edges at all.  It sounds like the drum is the problem.
Posted on Apr 28, 2008
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Could you tell me the load capacity to the hotpoint wma64 please
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
Jul 29, 2011 | Hotpoint WMA64 Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tiny Holes in My Cotton Shirts
If you have granite counter tops then they are ausing it - There is either a small chip in an area where you lean across a lot or your edges are too sharp ( usually with a bevel this happens). I had the same problem for 8 years! Recently put masking tape all the around the edges of my counter tops to test this. No new holes. Just paid a guy to come and smooth down the edges all the way around - expensive but the savings in therapy bills will be worth it- I had been driving myself crazy tring to figure it out and slowly eliminated all other suggestions. I read where one women just started wearing an apron and that solved it for her but I spend too much time in the kitchen for that.
Try the tape - it is a cheap (though not attractive) test. I left it on for a month to be sure. Make sure to check bathroom counters, laundry room ,etc.
Ann
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Whirpool Duet Front Load Washer
It may be the same problem we have, that the fabric softener is leaking before it's supposed to in the cycle.
If there is water left in the tray, the suction is not broken, and the fabric softener will immediately start leaking into the drum.  To stop this, we lift the fabric softener/bleach cup up out of that water to break the seal.  Leave it up for a few seconds.
That seems to do the trick.  Although, in my opinion, it should not happen to begin with.
Jul 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
LG WM-1832C Front Load Washer Logo
108 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
