Question about Philips 60PP9352 60" Rear Projection Television
Philips 60PP9352 60 in. tv
My philips 60" rear projection turns itself off after 3-4 seconds of powering up. The picture never actually comes on, it is just a blank screen and then it shuts itself off
  • chris theodosis Apr 19, 2008
  • 472 Answers
Do you hear the tubes crackle at all as they normally would when first firing up, or looking into the back of the set, can you see any light at the base of the 3 tubes when it is powered on.
You are best to get someone else to turn the set on, while you look into the back of the set. (keep clear obviously)
If not, then it could be the either the fly back transformer has failed, or the splitter the 3 tubes are fed from has failed.
Posted on Apr 19, 2008
  • Philips Master
  • 19,396 Answers
If your tv is not returning any diagnostinc message, for example red led flashing a number of times, then it is difficult to find out what the problem is without opening the tv and testing parts inside.
Usually, when tv turns off this way it is a short or a problem with power supply. Power supply must be tested first.
If it is not power supply or a short, defective control board can cause similar problem, turning tv off suddenly.
If you are an experience TV and electronix DIYer, then get your multimeter, test power unit and post back result here for more toubleshooting.
If you do not have a strong background in servicing TV, I suggest you to call a repairman in your area, the operation above must be done with live electicity in, and there is hig risk of hazard.
    Genius:
  • 1,447 Answers
Try using a different power cable if applicable and try hooking TV directly to a power outlet
  • Philips Master
  • 13,433 Answers
Seems there are some faulty or failed components in your set.
The mainboard or the powerboard might need to be replaced or some convergence ic chips / capasitors / resistors.
Unless you are willing todo that, I think the best solution is to take it in for service. Maybe another expert will have more exact knowledge on this problem?
Posted on Apr 15, 2008
No picture on tv a brief message before it turns itself off no input signal
check cables first...and then go to menu to assess if the unit itself is responsible for.
Mar 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Philips 109 cm rear projection TV model 43pp925
try unplugging the circuit board thats connected to the green picture tube thats the board in the middle then while the boards unplugged try to power up the tv if it works it means your green picture tube is shorted
May 25, 2008 | Televison & Video
Philips 60PP935217 60 in. Rear
I would check the regulator transistors and then the horizontal output tarnsistor.
Apr 09, 2008 | Philips 60PP9352 60" Rear Projection...
Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at blake.shewmaker@fnbky.com.
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
Picture problem
philips part# 483520988561 actual part# HCNW136 opto coupler datasheet at datasheetcatalog.com can buy many places just enter it on google.
other fixes philips part# 483520987834 actual # MC34065p and philips# 483520987712 actual# SC78104 some change all 3 and never have a problem again.
Nov 22, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
