Question about Samsung SyncMaster 203B LCD Monitor
Samsung lcd the power went out the other day and when i turn on my computer the error message comes up that in a gray box with red blue and green boxes that says "Check Cable Connection". i tried everything, how can i fix this?
  • 88 Answers
First It is not your monitor problem the problem is in your CPU
Open the Cabinet (CPU) door Took out RAM (Random Access Memory) after 5 miniuts Connect it
Thank U
Posted on Apr 16, 2008
My 70 inch sharp turned of now I have no red light nothing won't come on
Red LED usually means of not on. Green or white is usually on. Personally, I recommend one only buy Panasonic, Samsung, Toshiba and Sony TV and not Korea or Chinese junk like LG or Sharp. In the old days you could still get a Mexican made Zenith but now it's all from Asia and Japanese and Taiwanese products are a dozen times better then chinkware garbage. I never trust HD from China. They are junk. Only trust products from Taiwan, Malaysia or Japan.
Feb 01, 2015 | Sharp Lc70le734u 70 LCD TV
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
Forgot to color coade what goes where when taking out my stereo to put a new on in .. dont know which wire is for what
  1. LT Green - LR Speaker +
  2. Gray - RR Speaker +
  3. Red/Green - LCD Control (Light Dimmer Control)
  4. White/Black - Power
  5. Brown/Black - LF Speaker +
  6. Orange - RF Speaker +
  7. Green/Black - LR Speaker -
  8. Gray/Black - RR Speaker -
  9. Black - Ground
  10. Red/Yellow - LCD Input (Light Power Source)
  11. White - Memory Power Wire
  12. Brown/White - LF Speaker -
  13. Orange/Blue - RF Speaker -
Dec 07, 2009 | 1999 Chevrolet Tracker
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Still seeking db15 pin-outs for a samsung AQ17LS7LK
Here is the wiring colors for the VGA cable:
1- Red
2- Green
3- Blue
4- NC
5- Gray Shield
6- Red Shield
7- Green Shield
8- Blue Shield
9- NC
10- Violet
11- NC
12- Orange
13- Gray
14- Yellow
15- White
Apr 14, 2008 | Samsung SyncMaster 750S Monitor
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
