Maytag EpicZ has a F01 code. The machine will not start!
  • 3 Answers
I have had the same problem and I just fixed it. The f01 code was flashing and I left the machine on and pulled the cord out of the outlet and it restarted. Mine would not start, it would power on and you could select the type of wash and make any selection, but once you pressed start it would start flashing f01. I left if flashing and pulled the plug and it started working immediately.
Posted on Jul 23, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: I have a maytag EpicZ,
I just had this problem and I kept the washing machine on and flashing f01 and I pulled the power cord out of the outlet while it was still on and it reset it and I could start washing immediately.
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
Jan 29, 2015 | Maytag Dryers
Why is my Maytag Epicz model #MGDZ600TW2 not starting and giving me an error code F01. What does it mean?
The F01 error code is typically a communication fault. You may have a defective main control board. Unplug the dryer or turn off the breaker to the dryer. Double check to make sure dryer has no power. Remove the screws holding the top on at the back of the dryer. Standing in front of the dryer push down and slide the top away from you then lift. With the top removed you will see a metal bracket on the left side housing a control board. Remove the control board from the bracket. You may want to take a picture to reference where the wires go. Remove the white cover of the control board then gently remove the control board from the white housing by pressing in the small tabs. If you see a black mark on the back side of the control board and the white housing replace that control board. According to your model number the main control board is part number W10111606.
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
MAYTAG EPICZ DRYER ERROR CODE F-01
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
I have a maytag EpicZ, model # MHW2600TW00 with an error code of F01. Do you know how to clear this code?
May 27, 2008 | Maytag Washing Machines
Maytag epic z washer flashes f-01 error code
I had the same problem and the code f01 would flash, I could select the wash and make selections with all the other buttons but once I pushed start it would flash f01. I fixed the problem by not turning the machine off and pulling the power cord out of the wall and it seemed to reset it. I could immediately turn the machine on and it stared working.
May 22, 2008 | Washing Machines
Getting F01 error message on my maytag epicz
control bd problem remove top ..3 screws on rear.. control right front corner ck all wires first and pressure switch right rear corner
May 02, 2008 | Washing Machines
Washing Machines Logo
1,247 people viewed this question
Top Washing Machines Experts
