Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell Proheat Clearview - Belt and pump keep melting
I just replaced the belt and cog belt on my cleaner and as soon as I put everything back together again and started it up, the brushes would not spin, the belt melted and the metal cog on the end of the pump assembly melted out again. I can't for the life of me figure out why it's just burned out a second pump and belt in two days. Anyone have any ideas?
  • Anonymous Mar 23, 2014
    cogged belt broke and I cant figure out how to access it to replace it.
    President:
  • 1,673 Answers
Is the brush roll turning freely? Is there something binding the pump pulley or belt casuing it to not turn? Was the replacement pump a new one? If you replace these parts again, after doing so, try turning the pump pulley by hand to see if it will turn the brush roll easlly, if it doesn't then there is a problem.
Posted on Apr 15, 2008
Bissell Proheat Clearview 8905 pump replacement
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vbzb
Jul 09, 2010 | Bissell 1699 ProHeat Clear View Upright...
It just wont put any water out to clean carpet....Everything else works
That means that you need to replace the pump belt. Here is the belt you need, it includes instructions:
Bissell Proheat Pump Belt
Apr 13, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How to replace belt on a bissell proheat clearview plus carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jan 27, 2010 | Bissell 7901-R Clearview Proheat Plus...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
Broken belt how to fix i have a belt
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Shampooer
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to check the location of the pump belt?
Jun 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Carpet Cleaner
First remove the some cover on the lfet side that is on top, then turn unit over, remove the red lock plate, has 1 screw, pull it out, then you can pull the end cap out, remove it, the cogged belt is there. If while you have the brush roll off, the pump belt can be replaced also. REmove old belt, put new belt over the bigger round part of the pump pully, feed it thru opening, then from the top, grap it and stretch it over the motor shaft. Then put the cogged belt on and reinstall the brush roll and the red lock.
Jan 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
Power brush on Green Bissell power steamer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Sep 24, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
460 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
