Question about Refrigerators
I have a refrigerator in my unheated garage. How do I keep it working in sub freezing weather? mikescheetz@yahoo.com
    Genius:
  • 1,073 Answers
It will not work in sub freezing temps, the thermastat will not kick on if the temp is below 34 thus the freezer coil will thaw and anything is the freezer will melt, anything in the fresh food section below 32 will freeze 60 or below not recomended
Posted on Apr 15, 2008
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
NEW KNMORE REFRIGERATOR/FREEZER. UNIT IS A TOP FREEZER AND STS IN AN UNHEATED GARAGE. FREEZER FAILS TO FUNCTION WHEN TEMP GETS BELOW FREEZING IN THE GARAGE.
Yup, Many refrigerators will not run if the ambient temperature is below like 36 F. There are some good reasons for this that would take many pages to explain...
heatman101
Jan 17, 2011 | Kitchen Ranges
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
