Question about Whirlpool Duet GHW9150P Front Load Washer
How to replace outer tub front and rear
I have door , panel and bellow off whats the next step
    President:
  • Whirlpool Master
  • 2,651 Answers
Next step is to reinstall door and panel....
sorry, a bit of sarcasm,, the tub assy is replaced throught the rear of the unit not the fornt.
reomve the entire rear panel and 2 support rails as well. the top springs will need to be removed, and some how support the tub and remove the 4 suspension/shock aborbers, the drain pump aslo needs to be disconnected.the tub then lifts out the back, where you can seperate and reassemble the unit. be sure to mark the position of the silver clampps holding the tubs together, and i dont know why your changing the tub, i would also replace the inner stainless basket as well, (your in that far and if it was for noise issue, not a bad aidea, ahte to put back topgether and find the rear bearing has warped the inner basket support
Posted on Apr 18, 2008
How do I get to the barrel of my maytag neptune washer?
Barrel ? The inner spin basket or the outer tub ? Both require a lot of work. But everything has be removed, disconnected and or replaced. Front panel, door, rear panel, pulley, belt, flip up the top, all hoses and harnesses, top and bottom, front tub cover, bellows, un lip from the outer tub, cement block for weight, shocks on bottom and springs on top !
Feb 10, 2015 | Maytag Neptune MAH5500B Front Load Washer
Replace a door gasket on a whirlpool duet he washer
Hello, I think what you are trying to replace is instead termed as the bellows or in laymans terms the rubber boot on the washer that makes the seal with the front panel correct? You can also view this part on this schematic as part number 5 http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=29389401&pkw_=basket&model_id=5136839&NewWindow=1
Unplug The machines power from the wall. The correct way of doing this job is to remove the top cover of the unit by unscrewing the rear screws holding the top panel down and then sliding the panel towards the rear of the machine and removing the panel entirely. Next step would be to the control panel byunscrewing the control screws and seperate the plug connectors that plug the control to the wiring of the unit. You would then have panel number 4 as shown in this diagram that you would next start unscrewing http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=29389401&pkw_=basket&model_id=5136839&NewWindow=1
You would then use a flat screwdriver to pry over the outter metal retaining ring off the bellows and remove the front of the bellows from panel number 4. Note there maybe several small screws on the inside of panel 4 and sometimes to avoid the awkwardness some do remove the door as well from the panel. remove the panel from the machine. You would next remove the retaining ring around the front section of the outter tub by using either a 1/4" or 5/16" nut driver. Note when reinstalling the bellows after installing the new bellows on the tub replace the front panel. When trying to reinstall the front retaining ring that attaches the bellows to the front panel you may require a second set of hands to hold one section of the bellows while using a flat screwdriver and or a putty knife to pry the oppisite end to its proper seating position. If you have any further questions message me back and here is also a step by step video to give you the basic technicque
http://www.youtube.com/watch?v=EFDqUvBgxH4
I await your reply if you have any further questions.
Thank you
Rick
Jun 16, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Need to change front and rear bearings
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
(tip courtesy JSRock)
Thanks for using FixYa!
Dec 12, 2010 | Washing Machines
My washer {whirlpool duet} has started spinning unevenly, and squeeking loudly- can you tell me what is wrong?
It appears your rear tub bearing has failed in this instance.
DISASSEMBLY:
REASSEMBLY:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer The bearings at the large pulley are shot. Can I just replace the bearing or do I have to replace the back half of the outer tub? Can the bearing be replaced from the...
DISASSEMBLY:
REASSEMBLY:
May 12, 2010 | Kenmore HE2 Plus Front Load Washer
The door is leaking when the washer is in use
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
The first three sites have excellent exploded view parts illustrations you can use for part location and assembly. Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks around the bellow:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
My front loader washer is leaking at the door and it don't seem to get my clothes clean what do i do
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Has anyone replaced the bearings on a beko wma1512s
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a beko wma1512s washing machine the bearings video will be on the site next week
the bearing video will be here How to Replace Beko washing Machine Door Seal
Jun 18, 2009 | Washing Machines
Worn out drum bearing and seal
DISASSEMBLY:
REASSEMBLY:
Apr 09, 2009 | Washing Machines
Crack in outer tub of front loading washer
ARear Tub Bearing Replacement
DISASSEMBLY:
REASSEMBLY:
Mar 24, 2009 | Kenmore Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal De
