Question about Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 problems
We just purchased this item, it is not working, it said the battery was low, we just purchased this item on Jan 27, 2008 we tryed a 3 hour hookup to my computor but we got a brief working, but it went right back to the same thing, it shuts off, and will not come on, any ideas of what to do?????
thank you
Bev.
  • Anonymous May 08, 2008
    I have a Garmin c330 and it was used one time and it will not power up. How can I get it repaired? Where do you send it under waranty.
  • bigbreak1950 Jun 01, 2008
    plugged into computer 3 hours unplugged ubs tried to turn unit on will not come on
My c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Posted on May 03, 2008
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot battery no longer works
just bought a battery for my Garmin 330 C off ebay for around 20 and put it in myself, not a bit undertaking although you need a battery operated soldering device to make it easy.
Mar 31, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
GARMIN PROBLEMS
Had the same problem. Called Support. They answered immediately - a HUMAN, no recording, speaking American English - walked me through some tests, diagnosed a defective battery, gave me info on returning unit, I had it back in a flash. This is a classy outfit, and the Garmin C330 is a superb piece of equipment, has been flawless since.
Call 1-800-800-1020
Aug 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Battery
Remove front bezel by lifting just under the GARMIN name. Remove the 4 outer screws. Gently pull apart. Keep in mind the orientation of the antenna as it's a bit tricky to put back. The battery is mounted between the two speakers.
It's a round cylinder item attached to the main board by a plug. Problem is this plug also houses the connection to the speakers. If you are good at rewiring, cut the battery leads and reconnect them to the new battery. Not sure where to get the battery though.
When putting back the antenna, keep note of the tabs. The lower one remains on the outside of the shelf guide, and the upper one is on the inside of the shelf guide.b0d8aad.jpga47c0e7.jpg2a171e3.jpg
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't update software for StreetPilot C330
I have contacted Garmin several times till I got an acceptable answer. Some of the C330 receivers were sold to car rental agencies and contain software version 2.30. These units cannot be uodated. They are not reconized as a HD letter in "my computer" and mine would not accept a map update.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
