Question about Canon Pixma MP500 All-In-One InkJet Printer
Won't scan full page
My MP500 will scan anything less than a full page; ie. photos. However a full page scan results in a black to colored bar about 1-1/2" wide on the scan.
  • Cheesecheeks Jul 17, 2008
    When I try to scan a full-page document, it frequently breaks it into two different pieces, which I can't use. I don't have (or can't locate) a "Specify" button, so don't know how to adjust from "auto-select" to "Full". Any more suggestions?
In the control panel for the scanner, on the bottom left is a button labeled "Specify," where you can adjust how much of the page it scans. Sometimes it is "auto-detect," sometimes it is the size of a small photo, sometimes it is full page. You just have to set it to what you want. Usually auto-detect works, but sometimes it misses and only scans part of a full page, so you have to set it manually to full page.
Posted on Apr 21, 2008
My mp610 Canon printer will no longer print email documents (black)- leaves page blank, except for email address (in blue print)., But printer will still print satisfactory color pictures (Photos). B
Get the latest driver from Canon's web site. Then uninstall the printer. Remove the driver from your computer. Use regedit to remove any traces of your printer from your registry. Install the new driver. That should do it.
Jan 10, 2015 | Canon MP610 Photo All-In-One Printer
Color doesn't look like what is on computer screen... printing from InDesign and Photoshop... same results from each program.
first of all, your screen is probably not correctly calibrated to show the colors right. Same goes for your copier, try calibrating the colors. Press the menu button (it's a button next to the screen, looks like a star with a head around it)
- Then press Adjustments/Cleaning
- Auto Gradation Adjustment
- Full adjust
- Print page 1
- Put the paper on the copyglass, with the black toner facing the back of the machine.
- Press Scan
- Then Print page 2
- Scan page 2
- Print page 3
- Scan page 3.
Now the colors are calibrated. If it still doesn't match, try calibrating your computers screen so you can see the real colors.
Dec 21, 2010 | Canon imageRUNNER C3220 Color Copier
I can't scan an 8-1/2 x 11 sheet on one page-it creates two or three pictures. How do I get it to scan to one page?
Hi there. It sounds like you are not correctly setting up your page for scanning. Are you just putting the page in and hitting scan or are you going through the scan "wizard?" You need to let the scanner know what you are printing (color pic, black and white pic, text doc, etc.) and how big it is. Let me know what happens.
Jul 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon mp500 onlt scans part of the page
I was very frustrated by this problem too, but just found a fix at last!!
Instead of focussing on the settings on the scanner itself. Use the MP navigator software to change scan settings and get around this problem. there you can set document size, colour or black and white and even DPI (quality) .
Mar 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printing in black and white on Canon MP610
Mollmal...if you read the previous posts you would realize that the grayscale option still uses color....and does not solve the problem...there are two black ink cartridges in my printer...a small one that goes with all the color ones and a large black ink resevoir...the small one is completely empty...the big one is full....I think what people want to know is ....how do they print in black and white solely from the big one...I would like to know also
Feb 05, 2009 | Canon MP610 Photo All-In-One Printer
My Canon Pixma MP500 is printing only black.
Hey, Sound like something is wrong with the color cartridge. Replace the color one and try again. If that fails you might have to replace the printer as it doesn't sound like the problem is software related.
Dec 18, 2008 | Canon Pixma MP500 All-In-One InkJet...
Simply using too much ink
Your MP500 is similar to my MP780. I don't think you can get anything from the stores. It is hard to tell if the yield of 200 is accurate or not. It probably is but a lot depends o the images and text you are printing. If you print the color red, your yellow and magenta cartridges will be used to produce red. So in effect you will use up 2 colors to produce one color. To print something in greed your printer will mix the Cyan and Yellow (I think) and for blue it will mix Cyan and Magenta. So if you are wanting to print something for your own use, I suggest you print in black/greyscale only and in draft mode. However for presentation, I think it is best you do the standard printing. Black in draft mode I understand only uses the PG5 black cartridge. If you print anything in colors specially pictures, there is no way to accurately determine the yield and not a good idea to scrimp on the ink or else you get a poor quality picture.
Jul 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black does not print well
Try priting a test page to identify the color in questions.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Chances are you are running out of another color...
In reality the printers actually use other colors to print black, besides the black ink. (I.E. if its a picture etc...)
A greenish hue normally means your Magenta is running low.
http://en.wikipedia.org/wiki/CMYK_color_model
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
231 people viewed this question
old marine
old marine
Corne Viljoen
