Question about Lands Phones
Its saying no link to base,move closer to base, try again but the phone is right beside the base what do i need to do?
  • 6 more comments
  • kavwoody Apr 15, 2008
    i t saying no link to base move closer and try again. my phone is next to the base and still wont work
  • Anonymous Oct 07, 2008
    I have the same issue
  • bugeric24 Oct 17, 2008
    I have the very same issue. This is the second cordless phone I have had that has died in under one year and two months. No wonder everyone is going to cell phones....
  • Anonymous Nov 17, 2008
    I have the same problem .
  • Anonymous Mar 05, 2009
    it says that my phone has no link to base try moving closer to base. even when my phone is right next to the base
  • irishmimi Mar 09, 2009
    Has the Panasonic message "No link to base, move closer to base" problem been solved yet? I can't call out or receive calls; the message keeps appearing. HELP, please!!
  • Emily Ives 4 Mar 13, 2009
    Same problem with no link to base. Happening on one of two handsets.
  • Anonymous Mar 31, 2009
    Problem is no link to base, move closer to base did not fix the probleml-
    However, I unplugged all four phone lines from the main line and then proceeded to unplug it from the electrical outlet. Put in the four phone lines a before and then replugged the unit into the electricity and it appears to be working fine now.
I also have no link to base message but only on one of my two handsets. One works the other doesn't.
Any suggestions?
Posted on Apr 30, 2008
  • Brandon Guillermo Jan 30, 2011
    You might try removing the battery and replacing it. After trying everything recommended by the manual this is how I restored normal operation.
3 Suggested Answers
warlock13
  • 100 Answers
SOURCE: no link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Posted on Feb 23, 2010
SOURCE: phone
You might try removing then replacing the battery. After trying everything recommended in the manual this is how I restored normal operation.
Posted on Jan 30, 2011
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
When I press the talk button it says: No link to base. Move closer to base. Try again
Hand each phone up on the base and it will marry it. If you continue to have no link to base make sure everything is plugged in correctly. If it persists you probably have a defective phone.
Jan 25, 2011 | Panasonic KX-TG5632 Phone
Phone says no link to base phone stop working
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
Feb 28, 2010 | Panasonic Lands Phones
No link t move closer to base try again base
Feb 23, 2010 | Lands Phones
Can not dial out gives me a message that says no link to base
several things check the base is connected to mains power and switched on.
You have obviously checked to see if it is outof range,and checked the batteries.
If you are using more than one base check that you ar connected to the right one.
Also if you have too many appliances connected to the phone point they won`t run.
Nov 05, 2009 | Panasonic Phones KX-TG5571
Phones have no dial tone and a message that says
Unplug base (both connections) and re-plug them again. It works for me whenever this happens.
Mar 17, 2009 | Panasonic KX-TGA560M Cordless Expansion...
Phone
Apr 15, 2008 | Panasonic KX-TG5631 Cordless Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
Lands Phones Logo
1,032 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
