Question about Nakamichi SoundSpace 8 System
Only one speaker is working
How do I adjust the balance of the the speakers. The remote seems to allow me to do only a right or a left balance but not both.
I also have the same problem. in the begining both of the speakers were working now it's only one. it's not the balance setting either, i think i either blew something, but both of the speakers work when i switched the wires.
Posted on Jun 25, 2008
How to change balance from left to right on speakers without remote
If it was working fine you may find the speaker cable damaged or disconnected from the amplifier.
Feb 16, 2015 | Bose Audio Players & Recorders
Which universal remote will operate every aspect of my dav-ex150 sony home theater system? Would like to adjust the settings for the speakers. As of now I only have sound coming from sub woofer and front...
On your receiver you should have a 'surround mode' and a 'display mode' which activate the surround speakers. If you are not in a 'mode' just the 'left', 'right' and 'sub' speakers will work. As for a remote, many of the newer receivers can be controlled via 'App' through a phone or tablet.
I hope this helps
Jun 09, 2014 | Audio Players & Recorders
Hi, something is wrong with my receiver! My right speaker is not working when I put it into my right slot on receiver however the right speaker does work when I put it into my left slot on receiver. Can u...
There are two issues that may cause this:
1 - (most likely) someone has pushed the sound levels all the way to the left. Find out if there is a switch/knob/button (even on the remote) that will configure the balance of sound between left/right. Correct it.
2 - (probably likely) there is a loose connection somewhere. If you're good with a soldering iron, you can pop the top off of your receiver and test the connections to the right ports (where you;d plug in your speakers). If there is a broken point, repair it.
3 - (not likely) Aliens.
May 04, 2011 | Samsung HT-DS660T System
Only the subwoofer, front right, and front left speakers work. Is there a setting that I can adjust to turn the other 3 speakers on? Only 3 of the 6 speakers show up on the display.
When you do a speaker test it should show all speakers, if not then im not sure, but to hear sound from all speakers try pressing mode on remote and change setting to Matrix. Hope this helps.
Sep 18, 2010 | Samsung HT-Q70T System
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
I need help with my surround sound!!
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Jan 25, 2009 | Sony DAV-DZ100 System
Partial theft
As far as replacing the dvd any dvd player will work, as far as your LCR speakers go ( left, center, right ) it would be best to replace them with the same ones that came with the whole system, at least you want them to be same in size, power, and manufacture relative to the 2 rear speakers, at the very least the replacements should be same in size and power relative to the originals even if not from same manufacturer so as to attain relative level balance with the rear speakers, at the very very least any LCR replacement speakers will do really. The main point is keeping the relative balance between the LCR and rear speakers, the sub can be adjusted on its own. Sorry to hear about your theft by the way, that sucks.
Aug 04, 2008 | Bose Lifestyle 28 System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Left speakers is louder than the right
maybe you have unfair inputs!? or your balance control is not working good... or you have defective parts! or maybe they change value like resistors and small capacitors, or u have leak driver transistors...
Sep 14, 2007 | Onkyo HT-S780 System
Nakamichi SoundSpace 8 System Logo
157 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
ELECTRICLAW
Level 1 Expert
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
