Question about Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XT16 Projector starts up and picture becomes available, then shuts down in 45 seconds to 2 minutes. Filters are clean and unit has been shut off for over 24 hours. Will not stay on.
  • audioguru Dec 11, 2008
    Similar issue; the projector worked GREAT for about 3 weeks - then about 10 seconds after power-up sequence, it shuts off. The TEMP light comes on *very* briefly just before shut-down, maybe 40ms - not at ALL flashing or solid in any way. RESET button on back did not solve problem.
    It's been boxed since - we've been using another projector. Lamp seems okay - the SANYO logo startup screen is fine, as is signal until the quick shutdown.
    Possible PCB issue?
    Thanks
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
  • 563 Answers
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Posted on Apr 16, 2008
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
The projector is shuting down due to overheating after every 30min. how can i correct this?
There are four air filters that are accessible from the bottom of the projector .... make sure they are all clean.
Jul 18, 2011 | Sanyo PLC-XT16 Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
All filters are clean on unit but while warming up it locks out on warming temp. If all filters are clean what else would cause this fault?
hi,
check , is the fan is working or not. a fan is used for cooling the lamp,( through out till it is on.) if the fan is not working the lamp will get over heated and the worming message will come.check it first.
ok
Dec 22, 2010 | Sanyo PLC-XT16 Multimedia Projector
Whole projector (HD Pro Wide mutliview Model # PLV-70) shuts down after 10 minutes or so of use. Lamp is perfect.What do I do to fix this? . Happens nearly every time. Is there some control button I shoud...
overheating. clean out the projector with canned air. dust keeps in the heat. should be done periodically. about every 500 hours or so, depending on usage and environment. if it happens often after that, replace the thermosensor and check the fans.
Oct 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
Projector randomly shuts off
hi CLEAN IT!! all these things leads to 1 conclusion: the device is packed with tons of dust it has a safty powerdown on heatup http://www.fixya.com/user-guide/p196016,m4858,gm38/Sanyo-PLC-XP41-Multimedia-Projector.aspx good luck
Apr 06, 2006 | Sanyo PLC XP41 Multimedia Projector
Sanyo PLC-XT16 Multimedia Projector Logo
598 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
