Question about Ricoh Aficio 450 Copier
Waht can i do
My copy machine ricoh 450 has a fehler code of sc 548-00
  • mikemouse Apr 15, 2008
    i need assitant on how to repair my copy machine through my email
  • simmaa Apr 29, 2008
    ^when i turn on the copymachine it show code sc548-00 with a red light on tool side
  • 14 Answers
This SC Code indicates that the Fusing unit is either not installed or not installed prperly. The machine does not know it is there. Open the front door of the machine and the right door of the machine. In the upper right area(looking from the front) you should see a blue knob that you can turn. this is part of the fuser. There is one screw that you need to remove just under the knob. Then towards the upper left of the fuser there is a brown flexible lever, push it to the right and pull on the blue knob. The fuser will now slide out. Pull it out halfway and pushit in again until is sounds like it has securely seated itself, Reinstall the screw. Close all the covers. turn the machine on. when the code comes up do the following. Push the <yellow clear key>, <1>,<0>, <7> , then push and hold the red<stop> key for 4 seconds. (do all of this withinn 5 sec)The display screen should change to another screen. Turn the machine off, wait for 10 seconds and turn on. IF it still comes up with the same SC code you will need to have a servicecall . Hope this helps.
Dave T
Posted on Jun 01, 2008
Tell your mamma to bend over so you could shove it up her *** after that she may want the t.v next up her ***
Posted on Apr 16, 2008
  • 38 Answers
Fusing unit error check it
Posted on May 07, 2008
  • Ronaldo Panlaqui
    Ronaldo Panlaqui May 12, 2008
    CHECK YOUR FUSING SECTION BECAUSE NOT INSTALL PROPERLY
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh sc 672 error on new machine
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Feb 28, 2012 | Ricoh Aficio 450 Copier
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Sc 450 arıza kodu
first solution press reset yellow+107 and hold on red cancel ok if it appers again tell me your obsevation on your machine
Jan 03, 2011 | Ricoh Aficio 450 Copier
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
Error sc 551
try to SP reset then lets see what code appears
SP RESET
press Clear Mode 2x
107
press Clear Mode for 5 sec or until Copy Sp appears
Press Copy Sp
Exit
Turn off machine then on after 5 to 10 sec.
Aug 23, 2010 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Red wrench light in on, wont copy- no jams, display shows error, call for help - ricoh aficion 720 copier
first we need to know what is the code.
ex. SC_ _ _
after that we could lock on the problem.
the reset code for this is either off the machine and run SC reset clear/mode (yellow button) 107 press for about 5 seconds cancel button (red button) then exit off machine after 5 seconds on machine
Feb 26, 2010 | Ricoh Aficio 450 Copier
Customer has an Sc-405 code. They reset it by turning off machine then on. The machine only works for part of day then go's back into sc-405 code again.
that is a transfer belt error. transfer belt not moving away from the drum during ID sensor pattern check.possible main motor/ drive malfunction, trans. belt position sensor problem.
Nov 05, 2009 | Ricoh Aficio 450 Copier
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
158 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
