Question about Refrigerators
Kenmore Refrigerator making loud sounds at shutdown
For almost 3 months my 10 yr old Kenmore refrigerator has been making a loud sound like "2 knocks" when the compressor shuts down.
Other than that, the fridge and freezer seem to run fine.
We are upgrading the fridge and would like to give this one to
a neighbor. Of course, we don't want to give them a fridge that is
going to die soon.
Any advice would be appreciated!
  • Anonymous Mar 19, 2014
    all is working with refrigerator but makes a knocking noise and started after moving the fridge to paint behind.
  • Anonymous Mar 28, 2014
    What is a new fridge freezer on bottem supposed to sound like? Loud buzzing
  • 1,073 Answers
The compressor has a loose or broken spring inside the compressor, unfortunatly it can not be repaired without replacing the compressor, it could last many more years and it could quit as we speak.
best thing is to let the neighbor know of the problem and what is the repair that way they won't think you are ponning off the machine to them, it may outlast your new one, time will tell
Posted on Apr 15, 2008
I have a 10 yr old Maytag MTB2156GE, it has been making intermittent loud cracking noises for the last week or so, came home today it has stopped working. Can it be fixed? Is it worth fixing?
sounds like the condenser fan motor is bad check in the bottem back of the unit if the fan works if not replacing it is worth on a 10 yr old machine
Sep 02, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My old side by side Kenmore with Icemaker makes a loud rattling sound when it stops running. It is the existing refridgerator from when we bought our house so I don't have any warranty info on it. Any...
If the noise is loud enough that it sounds like somone knocking at your door then it is probably going to be the compressor. There are internal springs and is possible one broke. The only solution is to replace the compressor. It is also possible that the condencer fan motor is hitting something as well when it shuts off. You would have to look at it from the back as it shuts off after running.
Nov 02, 2010 | Kenmore 53642 / 53644 Side by Side...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Our Kenmore side by side refrigerator(#106 5682 603) has developed an occasional knocking sound - fairly loud. I obtained a new water filter from "" and have recently changed this filter...
If it sounds like it may be coming from the back of the freezer, it is the refrigerant "popping" as in feeds into the evaporator. Some models have this issue and there is a "fix" for it. (yours may not be this one though). Although the sound is annoying, it doesn't really hurt anything. That's not to say the icemaker isn't making the noise, or something else. But I am not sure where it is coming from.
Dec 31, 2009 | Kenmore 53642 / 53644 Side by Side...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerator and Freezer stopped cooling after intermittent noise
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerator makes lot of noise
titu, can you be more specific on what kind of noise you're hearing. If it's a squealing noise I would suspect either the evaporator or condensor fan. See if you can isolate where it's coming from. back.
Oct 12, 2006 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
