I have a Creative Zen Micro MP3 Player.When it tries to start up it shows the copyright screen and then Creative logo ,then freezes and the back lighting goes off. I have tried starting in recovery mode. I get the screen with the options and can select them but nothing happens and the lighting goes off.My PC cannot see the player when plugged in. Can you help. Norrie Rutherford
    Genius:
  • 1,447 Answers
You can reset your player if it exhibits any of the following symptoms.
  • Stops responding at the Creative or ZEN logo
  • Freezes or hangs at Building Library
  • Displays an error when it is not attached to a PC
  • The LCD display is blank
  • Does not power on at all.
For players with a removable battery, remove the battery and wait for 5 seconds, and then insert the battery again. For players with a built-in battery, push a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
Some players have one reset hole as well as a built-in microphone. DO NOT insert any object into the microphone.
I have a Creative Zen - zen_20gb_reset1.jpg If the player continues to freeze or fail to respond after a player reset, it is possible that the music library or some files are corrupt. It will be necessary to boot your player into its recovery mode (rescue mode), "clean up" the music library to remove broken links, or format it.
For specific instructions on how to access the Recovery Mode of an MP3 player, please refer to Knowledge Base article SID 4794.
It is recommended that you try these operations in the following sequence: reboot the player; clean up and reboot; format and reboot; and finally, reload the player's firmware.
  • Clean Up: It is the least destructive operation. It scans a player's hard disk and removes any invalid links from the music library. It does not affect music files themselves. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware. It is recommended that you clean up regularly if you frequently transfer files between a PC and your player.
  • Format All: It is the same as a Windows format performed in a PC, and consequently all contents will be lost after a format.
  • Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player. It requires the player be connected to a PC. Select this option ONLY if you have access to a PC and firmware available to install.
  • Reboot: Reboots the player. You can reboot the player after performing a clean-up or format, or reboot it without performing neither of them.
To update your player's firmware, please select the link below:
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool
Posted on Apr 15, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 15, 2008
    If that doesnt work here is the link for warranty info..
    http://us.creative.com/support/warranty/...
    pls dont forget to rate solution... Thanks!!
  • 13,433 Answers
Sound more like a hardware side problem, might also be a fault in software / firmware.
If you still have warranty it will save you, but since you have tryed to start in recovery mode already and noting happens it sounds more like a hardware problem.
I would take the mp3 in for service.
ofcourse there are a few things we could try,
repeatedly connecting and disconnecting the player from your pc and from difrent usb ports might solve the problem with pc not detecting it, check your device manager
start -> right click my computer -> manage -> on left side, device manager, open up the usb category and look what disapears and if you see anything with ! sign
also you can try to uninstall your usb ports (right click uninstall on all usb devices) and then reboot the pc and let it reinstall the ports.
let me know if you need more assistance.
Help my creative zen v plus freezes and wouldnt start up.
**** YOURSELF AND THEN TRY TO TURN IT ON IT ACTUALLY WORKS ... DON'T BELIEVE ME GO DO IT
Nov 08, 2008 | Creative Labs Zen V MP3 Player
Stuck on CREATIVE Screen
Take out battery and put it back in, see if it reset
Mar 20, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen MP3
You'll need to replace your LCD screen.
Aug 12, 2008 | Creative Labs Zen Micro MP3 Player
Creative MP3 keeps freezing up
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Feb 23, 2008 | Creative Labs Zen Micro MP3 Player
Zen creatives
Pushing the reset button shows the creative logo, copyright 2002 Creative Labs
http://forums.afterdawn.com/thread_view.cfm/307045
http://www.zenrepair.com/Zen/index.jsp
http://repair4player.org/disassembly_creative.html
Feb 19, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Zen v plus
sounds like bad hard drive try using the recovery tools at creative:
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Sep 01, 2007 | Creative Labs Zen Micro MP3 Player
Zen Micro Photo...freezes at Creative Logo
The microdrive is bad. Unfortunately you now have a brick. Microdrives are pretty expensive; you're best bet it to buy another MP3 player.
Aug 23, 2007 | Creative Labs Zen Touch MP3 Player
Player freezes at the "creative" logo
it is more likely the motherboard. try to download the firmware. if it is still doing it, then you are going to have to get the motherboard replaced. regards, connie
Jul 13, 2007 | Creative Labs Zen Micro MP3 Player
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
79 people viewed this question
 Grubhead
Grubhead
