I have a sharp tv model# 36us60
The blue comes in on my tv screen at all times,and it is blurry, i cannott adjust it out no matter what. how do i solve this problem?
  • 975 Answers
Its a technical issue ,probably you need to replace the IC chroma chip (hoping its a recent model make) its a chip with lots of pin 8 to 16 or more ,hope that helps.
Posted on Apr 16, 2008
Blue line, blue out of sinc along botttom 1/4 of tv
If this is a Rear Projection T.V, your CRT is going bad. You can take the front cover off and make slight adjustments on the blue screen control to get rid of any lines, as far as the blurriness of blue, that part is 500 dollars to fix. The most you can do is just get rid of the lines. There's a black box. Make sure you are very gentle with your adjustments. Just turn it back to how it was if the screen shuts off. I recommend turning down the brightness of the T.V. before you do this repair.
Jun 18, 2011 | Panasonic Televison & Video
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Blue color
On front bottom panel remove behind it will be your focus/screen block cobtrol adjust Blue screen drive and focus also how to enter service mode for convergence with set off PRESS and hold at same time ch-&vol- untill set comes back on release you should now be in service mode for convergence.
Feb 19, 2009 | RCA D52W19 52" Rear Projection Television
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
One side of blurryness
now one thing at a time. the picture that is blurr does it have red or blue lines on the rt or lt side it sounds like the convergence is out on the unit and that will cause the picture to be blurry. and is the big screen in warranty please let me know marty
Oct 09, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
