Question about Abit A17 Guru Motherboard
Abit Guru AI7 Windows Freezing
I hate this mobo so much right now. Not only was set up a monster (thank you Mike for helping me out), I can't install any new programs other than my virus protection. I never had trouble before the upgrade to the abit guru. Here's what happens...
Attempt to install the Sims 2-
Put in disk. Disk loads. Installation goes fine. As soon as I finalize the install the computer last 30 seconds before Windows freezes. The only way to get past the freeze is a restart. Then, as long as the new program is installed the freezing continues.
I had to system restore to fix the bug. Windows didn't even last long enough for me to uninstall.
Aol Install, sound drivers, bios update, all the same problem.
What is going on?!
    President:
  • 2,351 Answers
Hi Tinker_McGee, after installing you're virus protection did you run a full system scan? To make sure there is no virus being held in memory, please shut down the PC. Unplug the power cord. Remove you're memory for about 15 seconds & than firmely reseat. Reconnect the power cord & load windows. Shut off windows system restore. (Right click on My computer once & left click Properties. Click System Restore tab. Leave off until you run a full scan.
What is the name of you're hard drive? (If you say Maxtor), that can be you're problem. I personnaly know alot of people whi have had nothing but weird problems with their Maxtor hard drives.
I gather from you're last post everything went well for a little while during set-up of you're drive.
So, if it's not you're hard drive it can be any other device causing lock-ups. Let's try this. Boot the PC into you're bios.(Press the delete key every two seconds till you're at the main menu of you're bios). You want to go to, PC Health Status. Here you should be able to monitor the CPU's temperature & the mother board's temperature along with voltage & the CPU fan speed.
Stay here in the bios for awhile. Just walk away for about 10 minutes. We want to make sure the PC is not overheating or that the CPU's fan speed has dropped too far. Next, lets test you're memory. This might be hard to do if you're system keeps freezing because it involves downloading from the internet. Goto this link. http://www.memtest.org/
Scroll down the page till you see, -= Screenshots =-
Just below the three pictures is,
** Memtest86+ V2.01 (21/02/2008) ** Typed in red. Pick the file of you're choosing. Since windows is giving you a hard time, I suggest you download the bootable floppy disk software.
Download - Pre-Compiled package for Floppy (DOS - Win)
You can download the bootable CD software if you wish.
Once done, test you're memory. The only removable device is you're video card & I do not think it is that. Unless it is overheating. Over all everything you are doing is installations.
Installations primary device is you're hard drive. Last 2 questions. Did you connect a small internal speaker on you're board? When you boot the PC do you hear POST a single beep?
Keep me informed when trying the above.
Again Good Luck!
Mike
By the way, you do not need to keep posting in a new window when replying to the same problem. All you need to do is this.
How to vote you're expert.
Also how to repost more questions for same problem..
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 15, 2008
2 Suggested Answers
pgmadhav
  • 145 Answers
SOURCE: no audio device
First check if your motherboard has audio output. If yes, then install audio drivers from the CD provided with motherboard or download from net. This should solve the problem
Posted on Mar 14, 2009
My computer stopped working suddently. When I turn it on my abit uguru AI7 motherboard displays 8.3. then 0.3. and then 8.0. and that is it, I only ear a very low noice kind of siren and nothing else. I...
Try checking your power supply or swapping it with one from another computer. See if the low siren noise is coming out of the power supply or off the motherboard. That noise is usually a bad capacitor on the circuit. If it is on the motherboard you would need to replace it.
Let me know what you find, Thanks for using FixYa
May 14, 2011 | Abit AI7 Motherboard
I cant find drivers for the mother board
If you open the link provided you'll find all the drivers for your AI7 socket 478 motherboard listed;
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=AI7
Thank you for using Fixya!
Cheers
Mike
Aug 13, 2009 | Abit AI7 Motherboard
I have an old KT7 MOBO not sure if it's kt7a or just kt7
it may be the ram. download and run memtest86 at boot, before windows opens.
Mar 29, 2009 | Abit KT7A Motherboard
No audio device
Mar 14, 2009 | Abit A17 Guru Motherboard
Abit IL9 PRO V1.0 mobo
Try updating your bios to latest revision then using the windows update with it set to get updates other than mmicrosoft products (like microsoft update used to do instead of windows update in XP) this may work. Seems to with alot of the older boards i build systems with
Jan 21, 2009 | Abit IL9 Pro Motherboard
Two tone Siren from MoBo/over heating CPU
at first go to the bios. then default the bios setting. then check the system monitor. if the cpu is too hot you can see it. or you can change the processor. never over clock the processor.
Jan 20, 2009 | Abit AI7 Motherboard
ECS 6100sm-m
Download WD's software to test & setup drive. Try windows install again.
WD's link; http://support.wdc.com/download/index.asp?cxml=n
Mike
Apr 25, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Connect a vga card on a used a17 mobo
Hi Rafae183, yes, you're board, Abit Al7/Al7-G supports AGP8x/4x speeds & voltage of 0.8v/1.5volts only.
Below is the Abit link for you're board. Listed on the right of the page is product Inf. & support Inf. Suggest you add this to you're favorites.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket%20478&pPRODINFO=Specifications
Suggested any one of these AGP8x speed video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
Remember to check for voltage. You're video card must run at 1.5volts only. Warranty's are important too.
Have more questions, feel free to ask.
Best of luck to you!
Mike
Apr 12, 2008 | Abit A17 Guru Motherboard
Abit Guru Ai7 Hard Drive Problem
Simply....... no. Once formatted it's reinstall time.
You can load you're windows cd into the cdrom drive & try to get windows to load. If you do get the cdrom to load - (Press any key to load from cd...... ) & press any key. Once in windows setup ( DO NOT format the drive) but do reinstall windows, if windows see's another windows on your drive, great install over it. If windows does re-install it's self you should have enough time to install burner software & back up your personal data to CD or DVD before your partition looses it's cookies & shuts you down.
You can also leave it alone & install another drive & setup windows complete & slave it back into you're system for IDE.
SATA's are all master drives. Than copy your data back to you're new drive. In these cases I always suggest the user go to the web site of the hard drive & download the Mfg's bootable software tool's/setup utilities. Windows is not perfact at formatting.
Luck!
Mike
Apr 08, 2008 | Abit A17 Guru Motherboard
Abit A17 Guru Motherboard Logo
249 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
