Question about Compaq Armada M700 Notebook
Dim Screen First, I know little or nothing about a Gateway laptop. However, I am looking at a used Gateway Solo 1400. The screen is so dim it is useless. I was told the inverter was bad, but a new one didn't fix the problem. Hooked up to an external monitor, the computer works fine. Is there a brightness control or something that I can get to? Is maybe something else wrong? thanks
  • KyShark Apr 15, 2008
    Thanks, but the problem exists even when you first turn on the computer.
    Problem Solver:
  • 15 Answers
In the power saving options the screen may have been put down to save charge!
Posted on Apr 15, 2008
Gateway Laptop screen goes dim.
Please connect it to external monitor. If it is not affected there. there, it could be an issue with backlight or inverter.- a hardware issue.
Jun 03, 2013 | Gateway Computers & Internet
Screen is real dim, but I can see if use another monitor
The back light might have failed. You will need to have tis repaired if you cant do it yourself.
Nov 03, 2012 | Gateway C-140 C-140S C-140X C-140XL M280
Everything works fine but backlight on display is
Hi
Thank you for your query
Please try the following
1) Press the fn key + up arrow key
The above key combination increases the brightness on the screen
If this fails you have a faulty inverter in your laptop, this is relativley cheap to repair
If option1 doesnt work, please book the laptop into a reputable PC shop
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 18, 2010 | Gateway Solo 1450 Notebook
Dim screen, bright mouse pointer
Right click the battery icon on the right bottom of the screen in the task bar. The performance profile may be set to energy saver causing monitor to dim to save energy.
Sep 09, 2009 | Gateway Computers & Internet
Gateway screen flashes bright and dim
Usually the connection is one wire down the middle and their is another wire wrapped around it.
You can try to do a soldering job with heat shrink material around it, but if you don't know the procedure, it can damage the laptop.
Look at the charger and the amperage it needs as well as the voltage. You can actually just buy a new one as little as 80 dollars.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
IMAGE IS THERE SCREEN IS BLACK
This could be an inverter or backlight problem. If you are seeing the image as dim, then it could be with the inverter.
Aug 06, 2009 | Gateway Solo 1450 Notebook
Dim screen
If its very dark and you can barely see anything its probably a bad back-light. I'd suggest to take it to your local Best Buy. And yes, they can look up PSP#'s with your credit card, but even easier by telephone number.
Jun 24, 2008 | Gateway SL1450-30165297 Notebook
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
Help Please.
Is it so dim that the screen cannot be read with shining a flashlight into it? if so this is a hardware failure not a brightness setting. let me know if it is.
If it is just somewhat dim but readable, there is probably a hotkey. Gateway laptops are all different.
Google search for your particular model and specifications. you will get the gateway support page for your notebook.
for example if you have an mx6550 enter this at google.com
mx6550 specifications
Dec 17, 2007 | HP Compaq Presario V2000 Notebook
Gateway Notebook MX6027 - Dim Screen
Sorry to say the monitor is poked try to use a external monitor because theyre not cheap to replace. These guys are good and most likely tell you the same!!!
Oct 02, 2007 | Gateway MX6920 Notebook
Compaq Armada M700 Notebook Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
